interchangeable headrests??
1991notchbackLX
1,483
47
48
New York
hey, i've never posted in here before, i usually stick to 5.0 Talk/Tech since Fox bodies are my thing... some of you guys like Epik, SVT32VDOHC, and LaserSVT might recogniz me from over there... but anyway i have a question that i think applies to this forum
i have a set of '04 Cobra seats in my notch, they are in great shape except for the headrests, which are torn (i got them from a totalled car and the idiot tow truck driver threw the busted up rear bumper INSIDE the car when he towed it, so it chewed up the headrests)
are any other headrests from other seats in other stangs interchangeable?? Ford wants $180 a piece for the whole assemblies and doesn't sell just the leather to re-wrap them, hoping to score some on ebay or craigslist or a junkyard, anyway, sorry for the novel, and thanks in advance for any help!
Chris :nice:
random pics...
Good to see you over here bro....
Im not too sure, but maybe 99-04 GT headrests might fit? I know the dark charcoal color would be the same....
:EDIT... Nope they wont fit, they are too wide & lower profile...
Im sure Mach 1 headrests should be the same since the seats are shaped the same...
thanks for all the help guys! i'll be keeping my eye on that ebay auction and maybe calling some junkyards after the holiday... i know torn headrests are a little thing to complain about but i'm a perfectionist and little things like that bother me until they're fixed lol
thanks again guys :nice:
Also, look for a good upholstery shop. I have 2 that I use here in central FL and they do amazing work for extremely reasonable prices. The previous owner of my Mustang had the receiver for the satellite radio drilled into the dash and when I bought it, there were 2 lovely holes right in front of my face. They filled them, matched the grain pattern and painted it perfect for $75. I can't even tell where they were. Just a thought, Might save ya some money that way too.
back from the dead...
so i got a hold of some mint condition headrests from an '04 cobra, same color and everything, now how the hell do i remove the old ones?? :rlaugh: thanks in advance guys
Chris :nice:
I want to know this as well. I tried removing my headrest and it seriously seemed impossible. lol
And not to hijack, but these bigger headrest were on some GT's right? So I should be able to replace my small headrest with these ones?
does anyone have any info/methods/ideas?? i read some post i found from a search about sanding down a cable tie and sliding it down one of the holes and undoing some latch or something (??), but it didn't sound right or possible haha, grateful for any direction you guys can provide
Chris
Two methods
One is a thin bar like a slim jim. Slide it down the front of the headrest bar until you feel resistance. This is a locking tab. Then force it under the tab with a little wiggle while pulling up on the headrest.
Or number two is to unzip the seatback and slide your hand all the way up feeling for that tab on the frontside of the headrest bar. Slide a flathead screwdriver under it and turn slightly while pulling up the headrests.
Once you learn the trick, it takes a couple min
back from the dead... i CANNOT for the life of me get these old headrests off... i can get a thin piece of metal down the front of the headrest bar like you guys said, but i can't get the retaining clip (?) to release
what the hell am i doing wrong... an upholstery shop i called quoted me $100 per seat sight unseen... i hate living in NY sometimes :mad:
is there some magical jewel of information i'm missing that you 4.6 guys can provide? :D us 5.0 guys aren't used to these fancy seats :nice:
Chris
There is a slight trick not mentioned in this thread. I've swapped my GT headrests for the Mach/Cobra style.
I used a large plastic cable tie ("ty-wrap), the kind used for temporary handcuffs by the military in Iraq.
Lift the headrest as high as you can (which is only about an inch).
Working from the front of the seat, try to pry up (just a little) the plastic trim piece that surrounds the headrest blade where it enters the top of the seat.
The cable tie (or other suitable piece of stiff plastic or metal shim) gets shoved down in front of the trim piece, rather than against the metal blade. This povides a better angle that helps to keep it in contact with the blade inside the seat.
Stop when you can't push it in any further.
Now, here's the trick part:
Push down the headrest and shim together about 1/4"; this is what releases the internal retainer. Now, pull up on the headrest and it should come out.
It took me 2-3 tries the first time. Once I had the "feel", the other seat took about 10 seconds.
thanks! i used the heavy duty cable tie method you mentioned except i went in from the back of the seat and released the clip that way... 100 bucks a seat my lily white a$$! :D
so... does anyone need a set of lightly used 03/04 cobra headrests?? :rolleyes:
