- Oct 21, 2009
- 162
- 0
- 17
What is a normal operating temp for a mild 306? My mods include....Built AOD w/External Cooler, 4.10s, TF Stage 1 Cam, TF Intake, Pro Comp Heads, Pacesetter Headers, BBK CAI, 10:1 Comp.
I voted non of the above, reason: Get an autometer mechanical temp gauge and get back to us.
The stocker is a POS.
if your "pro comp" heads are aluminum it should run cooler than stock. Even in 115deg weather mine never goes over 220
I have the stock radiator and stock WP, but with the black magic fan (adj) I can have it run at whatever temp I set the fam to switch on. With that fan the car can sit at idle ltteraly all day long.
oh and if the system has a leak it wont have full pressure causing the boiling point to be much lower
I've tried that route but the sensor doesn't bolt up right. The bulb is easily pushed farther down in the manifold and the nut that comes attached to the cable doesn't fit right, the threaded part is the right size but the part where you turn is the same size as the threaded part, meaning the thing will just turn until the thing is inside the hole.
The sender's bulb is sandwiched between the fitting on the gauge side of the bulb (that you have) and a 3/8" NPT fitting that screws into the intake itself. The latter fitting is one you generally need to supply yourself (AM supplies a fitting for SBC's but not SBF's). The AM number is 2370 IIRC, but you might be able to use an adapter from the parts store (for their own line of gauges).
It's wierd, but you need another nut that's threaded on the inside and on the outside.
The bottom portion is threaded on the outside, and the top is on the inside.
Similar to this one, but i do NOT know if this is the exact fitting, it's been some time for me.
Auto Meter 2263 - Auto Meter Temperature Adapters - Overview - SummitRacing.com
You screw the fitting into the intake, then screw the fitting on the temp sensor into the one you just put on the intake.
