Ok - Im not mechnically savy enough to do a tranny job myself - so I sent it to this well-reviewed place nearby that was BBB recommended and such... the guy just called and told me this
The engine was great with 89K and worth keeping HOWEVER...
The tranny needed to be rebuilt, it needed:
bearing kit
main shaft
blocking rings
cluster
He said parts were $895 + labor (that hes already charging for taking it out) was $495 - hwoever it also needed:
clutch - $345 (racing - regular was $60 less)
rear main engine seal- $25
Flywheel - $65
Apparently the Seal was leaking oil onto the clutch with ate away at it - but hes not charging additional labor for any of that since they are already doing the work.
Total is $1695 with Tax, 6 month warranty on the parts, 1 year on the Clutch.
What do you guys think?
bearing kit
main shaft
blocking rings
cluster
Flywheel - $65
