Forced Induction Vortech V3-si On 1994 Cobra
How much torque?? And yeah the heat kills timing. It seems to be the norm now for tuners to have the computer pulls massive amounts of timing when the air heats up. Sounds like you need a meth injection kit like I do. Your car made 8 more HP at the wheels than mine and my car has a bone stock GT long block! Yours should have made more I think.
What were the ambient temps?
Yep I'll post a picture as soon as I get it. Ambient temp was 75. But muggy as hell, I dont know if that plays into it. I actually really loved it. Hearing that thing rip on the dyno in the garage was an adrenaline shot to the heart.
To be honest your heads/cam/intake aren't what is holding you back right now. It's heat and though h/c/i will make your boost drop slightly (btw what boost did you make peak power at?) you'll still be cramming tons of heat down the throat of that motor. The timing retard is killing your power. Before H/C/I I'd suggest a meth injection system. It will increase your octane and lower your charge temp allowing more timing to be used. Each degree of timing increase that you can safely use will equal a ton more power.
To put it in prospective my old 95 GT with pretty much the same combo I have now laid down 425 to the wheels. It was a very cold winter day when I did that so the charge temps where much cooler. On that dyno run the motor realized 20* of timing. Fast forward to my existing combo it was hot outside and it only put down 370 max with a 350 average. Timing was down to 13-14* due to the 200*+ charge temps. So you see retarding the timing can cost a lot of power, so fixing that should be your first priority over changing your motor's top end. Besides, a Snow meth kit is only 300 bucks. Much cheaper than a new top end.
Pump gas is fine. The meth injection actually raises your octane level and with it's cooling effect allows you to run much more timing without fear of detonation. Your tuner will have to put it back on the dyno to tune for the meth injection but even a retune + the meth kit will still be a fraction of the cost of a new top end kit.
I'm planning to do the same myself before I step into building a new engine. And when I do that I'm either going to a dart/boss block or a windsor. I'm not wasting money building a stock block 302 that will be in block splitting territory!
That is where I was thinking would be a good place for it but the guy who tuned my car told me to put it before the blower and use 100% methanol. That is how he has been installing them since 2005 with allegedly no problems.
2 problems with that. First, the blower is going to just heat the air right back up again. Second, 100% methanol is a bomb and it really isn't as easily available as 50/50 mix. Plus, do you really want some kind of substance hitting your impeller as it's spinning at 50,000 + RPM? I know people get away with it but it just doesn't seem logical to me. Also if you read what others have to say about the Mr. Freeze vs Snow kits you'll see that they don't really like putting it before the blower. I think Pops Fun tried putting the nozzle pre blower and didn't help at all.
Either way, my tuner told me to put it post blower and gave the same reasons I just did. He is one of the best tuners in the country and actually goes around teaching other tuners how to use their SCT software.
There is a lot of contradictory information out there on this issue. The guy who wrote the SCT tuning manual says to inject it before the blower. He is on this forum; maybe we can get him to chime in.
