What would happen if....
95Vert383AOD
1,133
34
69
New Bedford, MA
.... I ran out of space between the fan and engine area so i mounted a universal coolant reservoir in front of the radiator behind the bumper but its mounted lower than the radiator.
I ask this because i have had coolant disappearing. I drive and park it and no matter what the radiator is exactly 1/4 low. Also i sometimes experienced overheating but could find no links. Today googling around i'm reading the overflow must sit as high as the radiator.
Whatcha guys think?
Chris
Mine is mounted just above the framerail in the driver's side bumper cover area.
So, its at about half the height of the radiator itself.
Moved it due to supercharger belt clearance issue.
Been that way for about 6 years or so. No issues.
mines an 89, but is tucked up in the fenderwell also
I'm not sure the combustion would even make it into the coolant. the heads have loc-wires to seal the combustion chamber.... I'll check anyways and if i still have a leak ill go over the head bolts to see if maybe something loosened.
