Hello,
I recently pulled a 1990 5.0 for a donor motor to put into my 1968. Engine was completely rebuilt. I went back with typhoon upper and lower intake, anderson n41 cam, and twisted wedge 170cc heads. Also went with 27lb Bosch injectors. I used a painless performance 60510 harness to get this set up in the old stang. It also has a tremec 5 speed. Car has a brand new walbro 255lph inline fuel pump. I blocked off the egr, it is unplugged. The MAP sensors, intake air temp, water temp, IAC, TPS, and MAF are all in use. bama has burned a chip for the A9L computer in the car. MAF, TPS, and TFI module are all brand new. I am not running o2 sensors as I have long tube headers and the bungs are welded on just down streem of the collector. I will run o2 sensors if I can get the car to run good enough to make it to the muffler shop.
Here is my issue:
With the MAF plugged in the car idles a little on the rough side and hangs at a high idle for too long after you get engine rpm up. When you punch the throttle engine completely cuts off. As soon as you let off the throttle it runs again.
With MAf unplugged, The car runs 100% better. throttle has instant response and it idles flawlessly
The only codes I can get are:
15
85-CANP failure
96- fuel relay
Has anyone ever had these symptoms?? Am I missing any sensors that should have been transferred from the fox body? Any help would be greatly appreciated!
Thanks
Here is my issue:
15
85-CANP failure
96- fuel relay
Thanks
