I guess I need to start this by giving recognition to the wife. She made today's dinner, did some laundry, bought the three tickets to the 3:30 showing of Superman vs Batman, and still allowed me a couple of hours in the garage.
The dinner was great,...Now I got clean clothes for the week, and Who in their right mind would take on Superman? The movie was better than Starwars (which just plain sucked) but I got a problem with the premise. Why Batman had such a hard on to kill Superman was just dumb......Other than getting over that hurdle,It was ok.....For a Super hero movie anyway.
I said earlier today that I needed to do a few things so that I could move the car on to a point where I could entertain/consider masking the whole thing up and blasting it with three coats of 2k.
In the two hours I had, this is what I did:
The oil cooler shroud and the front bumper wearing their third coat of rattle can high build. The shroud has some wonkiness to it, but I'm thinkin that that is just gonna have to do. It sits beneath the front bumper, and will be so low that you'd literally have to get on the ground to critique it. I'm thinkin' I'm calling that dude done after this round of blocking. I sagged the primer on the front bumper, but it's still got it's blocking to be done as well. The same as the shroud, if it looks good after all the wet sanding is done,...it's gonna get hung somewhere safe.
The holes you see are my locators. All four hinges are now "staked" so I can remove the doors for paint.
Both rockers,...devoid of paint. That was no simple process. The plan to remove that paint started w/80 grit on a D/A sander. After a couple minutes of that, it became apparent that going that route was gonna take more time than I wanted it to,..(and remember,..I only had a couple of hours). I put a wire wheel on the 4.5" grinder and started down that path.
It would've been the right path, had the wire wheel NOT came from HF. For whatever reason, the wires in the wire wheel became lopsided, and the vibration that came as a result of that was just plain dangerous. Had I not had a serious glove on my right hand, there would be a significant amount of missing skin on top of my right hand as a direct result of using that junk.
That forced option 3 into play: A propane torch, and a hand held wire brush.
That option made quick work of the whole deal, but I also managed to put two small warps in each of the bottoms of the rockers because of the heat. It occurred in the same places on both sides, so there must be some structure underneath at those locations that makes it susceptible to warpage there. Again,...very bottom of the underside of the rockers, You're gonna have to lay down to see that, and when the car is at ride height,......Aint happenin'. But in the pic that has the lighting in front, you can see the warps big as hell,....I just gotta see if they can be seen from standing, and whether they affect the crown of the rocker.
So,.....where does this leave me? It puts me in a place where I have a bunch of small pieces that need orange paint on them:
The front bumper and the shroud. The grille surround, and the head light bezels, The hinges and the door handles, And the G hole. The front bumper could be painted, and the shroud could be bolted on permanently. Since the fenders basically "cap" the bumper at the ends, and since I intend to paint them off the car as well, making the bumper permanent will work. By painting all of the other small pieces that you'd ordinarily have to chase down last,.... first, I'm thinking piddly little shi t out of the way.
What say you to that one
@Davedacarpainter ?
