Progress Thread Project: Buried Under A Mountain Of Snow Black Hole Money Pit.
and no im not done welding the brackets on.
the batteries in my mask died on me and i got tired of getting flashed.
btw i really didnt expect the axle tubes to take as much heat as im using...
depending how long it is till the guy doing the cage can get it in... i might pull the rear out finish welding the coil over brackets. and id like to get the UPR ARB tacked in place also. might do that this weekend. when the rears out i might cut the wheel tubs and finish the mini tub myself.
but all that depends when the guy doing the cage can start
the frame is welded up... nut setter will be here today.
i think im going to pull the coil overs off and pull the rear out. then weld the brackets up and cut the wheel tubs. after that i can put the wheel tubs in and the mini tub will be done.
and with the rear out i can get in and weld the coil over bar in better and get the ARB welded in place also.
have a few other things planned while the rear is out also :)
Busy, busy time man.
Lots easier to weld in the back with no rear end, that's for sure.
Can't wait to see the progress.
finally making a little progress...
car goes sunday to get the chassis done...
trans will be out tomorrow.
oil pan will be here tomorrow
overhead switch panel will be here friday
gotta go pick up some 2x3 steel tubes here soon i guess...
welp....
for the first time since i got the car it hasnt been in my garage or my mothers garage...
im not a fan! but shes in good hands for the next few months
i will try to get over there and get some pictures of it while its in progress
doing mini tubs
thru the floor sub frames
ARB
10pt cage.... and might add a few more bars in it
