is there a way to add another kpa row between 160 and 200? In other words,...boost at 10 psi is 168.2 kpa on my tuning tables.
If we could set the AFR table into rows of 10 from maybe 130 up.....is that do able? Is it even necessary?
I was just looking at the datalog I had to compare against Collin's and because the rows are so far apart, once everything starts to transition through the table timing falls dramatically almost straight through the floor, and then the slope decreases to a more gradual retard when it's making boost.
It's looks as though it falls off dramatically because you have multiple lines running on different scales.... it also depends on how timing is being pulled, is it setup linear? Or does each row pull it's own amount?
If you are pulling timing linearly you technically only need one row above 100kpa.
Let's say you wanted to pull 1* per psi up to 15psi. With a wot total of 27* at 100kpa.
Simply set the 100kpa row to 27*
Then make a row above it at 203kpa with timing set to 12*
The boost retard will be a perfectly linear 1*per psi up to 15psi where it will level off to 12. But it will not retard past 12 even if you pummel 30psi into it.
Sometimes fewer rows is better so that you don't play with the number in between them too much. One row above 100kpa with your total retard amount is much simpler and will act more like a BTM. Set it and forget it.
Reactions: hoopty5.0
So,.....off early today,...courtesy of the weatherman.
When I get home,...three boxes from Amazon are standing in the door way.....(wonder what's inside) This was supposed to be one of my better kept secrets from the wife because if she finds out that :
A. These things cost 440.00 when I am constantly complaining about never having any money (now that I'm on the regular "fixed" BMW income)
B. That I applied for 6mo same as cash to pay for them,...even though it's entirely on me
She'll have a come apart.
So,....I got the two Turbosmart gates,.....These are the models that my Chinee copies were made off of...
Actually it's kinda ironic. The Turbosmart gates are domestic.........If you live in New South Wales, Australia that is.
One more Australian add-on.
Anybody interested how different the domestic vs the Chinee copy actually is?
Ok,...I aint given you no video.
You just have to suffice w/ stills and my witty commentary.:rolleyes:
When last we remember The chinee waste gates wouldn't open until 14 p.s.i., despite the fact that they had 5 pound springs.
The reason for the HUGE difference was due to the slop between the valve, and the guide. MOF, air was escaping so significantly,..it literally backed up against the palm of your hand when you blocked both the inlet and outlet w/ the palms of your hand.
When you have an engine that has an unknown compression ration due to the fact that I have either got dimensia, alzheimers, oldtimers, or some other brain disintegrating illness,...having no clue where your boost is gonna top out would be......................
Bad. Yes,.....let's just say that having a wastegate just arbitrarily decide to spike up to 15p.s.i. would be extremely bad.
So,...they needed to go.
I will not rehash the jugphck that took place to get two new gates, but let me just say this about that...they are lucky that those gates arrived here today. Especially considering that this city has effectively shut down due to the fact that we are in an ice storm as of this minute.
But I digress.
I open the gates and immediately you can see the difference. The quality of the part is obvious. The valve is similar to what you'd expect in a high perf automotive engine, and had a stepped tapered stem. When you look at the Chinee gate,..big ole Klondor looking thing, w/ no taper.
The Tsmart gate is significantly heavier than the Chinee copy. Probably the difference between alloys on the body castings and internals making up the difference there.
The thing passes the "Why did I pay 4 times more than a Chinee piece" test just by sight and feel.
But I needed to do the pressure test to complete my review.
I rigged up the exact same tester that I used on the Ding-Pao version, and applied slow incremented pressure to the bottom port of the gate. (These things are supposed to have 7 pound springs).
Gate #1 (The blue gate):
The gate started to crack open at 8.5 pounds, and was fully open at 15 p.s.i. There was zero leakage past the guide, and every other time I applied pressure to the gate it did the exact same thing.
Gate #2 (The black gate):
This one started to open at 8 p.s.i, and was also fully open by 15 p.s.i. It also duplicated that standard everytime I re-applied pressure.
That left me w/ a half pound discrepancy between the gates.
Do I care about that?
Do I have to get the finger out for a final answer?...........................well?:chin.....................Of course not.
Not only does the finger say no,..The fingers says Hell no!
So,..I got these two gates,..one is black, and one is blue. Considering that I name almost everything when I talk about this car...
(i.e Winkin, and Blinkin,...G vents/Gills/Nostrils/Hole,)........... I'd guess that you'd think I'd probably have a name for the waste gates.
No silly,...they're wastegates. Why in the hell would I name some inanimate object? :shrug:
I'm all prattled out,....I guess I'll tie this up with my pictorial.
Now I'm gonna tell ya,...That back blue gate is a sonofabtch to put on,..you can bet I was cussing up a storm.
So,...I'm back in the boost business. The only casualty was one hard line,...For whatever reason there was enough difference between the Chinee and the Aussie, that that short hard line looked like ass. So,..I'll have to make a new one.
In the mean time,..I'm drinkin grapefruit tasting beer.
And I have a "don't ask, don't tell" thingy going on w/ the wife,.....She didn't ask,....and I'm not tellin.
You'll mess around and match your gates....black and blue. Lol
Wear the helmet cam while she kicks your butt.... We'll be watching.
Edit; the head cam thingy...
For your sake I hope the Monster is fast as hell....you're going to need it buddy.
Reactions: A5literMan
They look nice Mike, and as Billy Crystal used to say, "it's better to look good, than to feel good."
I hope they feel good too.
Ice storm? When i was stationed there for a short period of time back in the early eighties we had an "ice storm", you think it was armageddon! LOL!
Alabama is worse than Oklahoma, i have to admit, when it comes to inclement cold weather.
I'm looking forward to a "driving with CONTROLLED boost" video.
I was leaning toward the first one. More sleeper.
Anyone else notice in the list of mods of the first one, "Ebay head studs"? All that work and money, and you skimp on head studs??? I feel like there may be a disclaimer in there in size .00003 font that says, "needs head gaskets at minimum, should probably check out all internal bearings."
Unfortunately I won't be buying too much from Amazon anymore because they are now charging sales tax for Louisiana.:mad: I guess I'll be going back to ebay.:nonono:
Amazon collecting sales taxes keeps us from having to keep track and claim it on the state taxes each year if you prefer not to cheat. I am not impressed with the junk from China on eBay or how they treat honest sellers anymore. Amazon has been good about fair fixing things when two transactions went wrong.
Mike,
Those other Fairmonts are a good reminder how far you took it. Even with bad knees!
