In the movie Risky Business, Miles tells Joel "Sometimes you just gotta say what the fck,....Make your move."
I like that movie.
This morning I get up, I'm faced with two different scenarios with regard to what I needed to get done.
Scenario #1. Fix, and repaint the basement bedroom.
Or.....
Get the Monster back together.
What was it that that guy on Risky Business said?.......
Oh yeah! ................Sometimes you just gotta say what the fck.
I made my move.
The Monster runs.
I changed a few things up,...I had the charge tube powder coated. I installed a PCV system,...I plumbed in my cheap assed adjustable boost control valve..I moved the fidle valve inlet onto the intake and got it off the VB so that maybe it would stop stinkin whistling...I added some braided hoses.....I sent the pump away to get them to stop the damn leaks,...I re-sealed the side cover,......I painted the engine wrinkle black...
And I named the engine.
Not bad for a months work.
And you just gotta know that I have a thing for ford emblems, that cause onlookers to scratch their heads and wonder...
"Hey Jeeter?......Did them Ford boys in Australia make a six cylinder that was fuel injected, turbocharged,..and roller cammed, and ,......Did they call it a Cobra Jet?
If they didn't.....They do now.
Shiny!
That's actually a PCV valve screwed into the elbow.....That way It'll hopefully help suck some of the fumes, and vapor that waft out from under the left front fender...
I
put crammed one of the little stainless steel afro balls that
@jrichker suggested To help keep the engine from sucking wet oil back in at high vacuum....We'll see how that works this Friday night.
Friday Night starts "First Friday" in Gadsden Al. I hope to make that this Friday. It's about as cool as a cruise-in can get,...The whole downtown shuts down,...Typical attendance is 800-900 cars. All of the local vendors remain open,..several bands,...Big doin's. Hopefully the engine is up to the 100 mile round trip.
Lastly there's this turd....
This thing is about the biggest piece of dog doogers that can pass itself off as a boost controller. The only thing I think that is lower than this thing is a home made version. Under that top knob is a spring and a ball bearing. The side has a tiny little hole drilled into it to allow trapped air pressure to escape when boost pushes the ball off of it's seat and it gets passed to the wastegates. The problem is that locknut. You loosen it, turn the adjusting screw, then tighten the locknut back.
Simple enough right?
It's backed off all of the way right now,..and there is about 1 thread holding the whole mess together. trying to screw the adjusting screw into the controller so that more threads are "biting" loads that spring..So,......In essence it's gonna add something to the WG's almost immediately....gotta be real conservative the first time out with this thing..
I don't need a T.N.M. like that young guy in Houston...
But does it leak?......You gotta be asking yourself that....
Well,....I'm glad you asked...To which I'll simply say...
Nope.
Not yet.
