The metal is too thin to seam weld within my limited talents. I tacked welded about a bagillion times around the perimeter.Those Scott Rod panels look amazing! I'm leaning towards buying those for my bay. I've got a few questions if you don't mind. Did you cut out your old aprons because they were damaged? (It's probably in your build thread somewhere, but damn that thread is long!) Did you seam weld the panels in or tack them in? I have access to a panel bond gun and thought about going that route. Did you have to use filler on them before painting? Thanks man, sorry to keep dragging you in here, haha
Yep, bondo. The left side I accidentally bent by tripping. Mud on that one, then also after grinding the welds down to give it a smooth appearance.
I suppose they could be PBA'd in. Though I would worry about the flexing of the front end causing problems. Speculation is all there, I really haven't given it serious thought or study.
The old panels weren't damaged, and I see the validity of leaving the old ones there for tucking the wiring. I've worked in a bodyshop for a long time now and it didn't really enter my mind to not remove the old one. I just thought, these are beautiful replacement panels. So I replaced.
