Fox Need Suggestions
Should I swap the motor or work on the v6?
  • Total voters
Well,...you are in for a long wait.
Be advised:
The K member will have to be changed out to allow that 351 to mount. The transmission behind the 3.3 will not work either. There is a 7.5" rear in your car, and it will need to be changed out as well.
More than likely you'll need a different oil pan.
Since your current fuel system is carbureted, swapping the 351 over to a carburetor will be the easier path,...
If that engine runs, Leave it alone. Change out the pan, swap the intake and put a carburetor on it. In reading through this thread, I think that you're biting off more than you can chew,..but hey, you gotta learn somewhere.
I think you'd be better off finding, and getting a donor Mustang that has a complete 5.0 and it's related running gear and using that as a swap source. As much stuff as you have to change out on the current car will take a very long time unless you have about 10k sitting in a bank,...and if you do,..I'd sell the whole 79 car and buy a completed project. You can buy sweat for .50 on the dollar.
I picked up the 351w yesterday so now I just need to start cleaning the engine up
You're going to be in for at least 4k like boosted said. I personally can't justify that for a 302 when for a few pennies more you can have a 347.
If it was me, this is just me mind you I'd be looking at 351 or bigger.
While this sounds really good; And believe me I want this done to my project; the truth is if you're gonna swap you should buy a donor to simplify and even then you will need a lot of time and a lot of money. I am on the road you are about to venture down right now with a fox wagon build. Be prepared for a long haul. I am blue collar with a family so it is taking forever to find the time and money. I work overtime so I can afford my parts but then I don't have the time and energy to wrench. I believe I see light at the end of the tunnel, but it's dim.
Reactions: uhHollow
I talked to a tech at lunati years ago when piecing together my junk and they told me that the voodoo series cams are not well suited for efi.
If I remember right, which is rare, there is too much overlap, both valves open, thats what gives it that distinct sound.
