Rolling Wheel Wells - Post Up Your Stance Pics!
billison
I like tinted tail
2,607
1,094
184
stl
So I'm close to tossing paint on my fox. Last night I was looking at the wheel wells and their need to be rolled. If I do it, I'll get a roller. My main concern is the roller reshaping the quarter panel. Anyone have experience with these?
I've also wondered if I should change my wheel/tire choice and just leave it alone.
Well, I am a little different. I am not a fan of rolling the wheel wells personally. But that's just me. With the proper axles and backspacing there is no reason to roll the lips unless you are putting HUGE tires on the back. I have pretty wide tires on the back, 275/40/17 with fox length 5 lug axles and no rolled lip and absolutely no rubbing or clearance issues.
I'm currently fox length outback with 285 rears ( came with the wheels) and plan to drop to a 275 later. Just trying to be safe.
Figure $40 for a roller is cheap and easy
I do agree that if your mind is set on doing it now is the time before you paint. It's just a personal thing with me that I find the rolled fenders something you can't undo...at least not easily. So, if it didn't turn out the way you hoped...you're stuck.
I see it as a"what have you got to lose?" if you do it now. Who cares how many other cars run what they run and get away with it? That'll all change the day you decide to run a set of ** insert size** tires, mounted to the wheel you've always wanted w/ a "Never fit in a million years" BS/Offset, that was just too good of a deal to pass up.
If you wait until after you've painted, then the whole paint job on the fender/quarter becomes an issue. Better to try and fix it now when it's only body work, then after, when it's bodywork and new paint.
Show me another Fairmont that can get away w/ this ride height,...and you'll find another example of a Fairmont w/ flattened inner wheel lips.
There is a lot of " give" w/o having to cut reliefs into the inner lip when somebody (me) decides to start smacking the inner lip w/a 2 lb sledge. It just takes patience, backing up the shiny side w/ some sort of sand bag/ shot bag, and doing it gradually. Ultimately, the only part that needs to be flattened is the top part of the lip where tire sidewall contact starts to come into play. Since my car is the only one where anybody offered up a "stance pic" I'll point out that you can see the flattening start to get more serious at about the 10 o clock/2 o clock in the arch of the openings.
To each their own though,..personally I'd take a flattened inner lip that can't be seen too obviously to a giant bite mark out of the tire sidewall that would be visible after the fact any day.
Reactions: General karthief
I ordered the roller. I'll post once it's here and I start the process. This way I can fix any chips or cracks that may happen and get a good primer behind the lip as well.
