That's gonna take a minute...I'm none too thrilled about having to get under the car, and....id have no place ( engine stand) to put it when it's out.Get to the rings! The people need to know.
I have an engine building friend with 4 of them.Irony is the word of today. I have an engine stand sitting in my garage you can use if you want to swing by. Only thing I actually bought during my engine swap.
I don't expect that,..but I'm betting that there'll be at least a couple of bearings with dirt/ debris lodged in them.The last time I had to teardown the oil was full of metal from a failed honing job I did at home.... bad idea btw....
The pan magnets and filter stopped all the metal from reaching the bearings, given the car only idled for a bit before the rings gave up.
Maybe you will be as lucky
BMW e-46 TB's.I can tune independent throttle bodies......
BMW e-46 TB's.
These things can be bought for 400 bucks on eBay...I'd build a transition adapter to allow for the difference in bore spacing,...it could be cool...
Moron he says...Doesn't want me to throw away "all that work"....Quit being a moron. All the work you have done to accommodate your turbo, and youre gonna go N/A? GTFO
Yeah,.....If that's not moronic, I don't know what is.....stupid me,....thinking maybe I'd tame it down,...enjoy the visceral experience of a roller cammed, individual throttle bodied port injected, N/A combo that isn't on a path to self destruction because it's a 6 cylinder that probably wont make more than 250hp and would be an instant let down.
Like for instance .......
Some 86 project car that I bail on,....
Some 2011 car project that I bail on...
Some small pick up project that I bail on...
All to return to his "high school roots"
Which Incidently is a project theme ......that he bailed on...a " warmed over" stock rebuild that now has evolved to a stroker motor, big brake, retro mod that has a bumper on it that hadn't even been invented yet when his car was roaming his high school parking lot.
You and I know that I won't divert the monster engine from its path towards eventual destruction. 11 pounds today, 15 pounds when it goes back together, 18 pounds, 20 pounds, then rod failure,....cracked cylinder walls, broken main saddles...and what's left of a connecting rod jammed into a combustion chamber.........
That gets followed up with a New block, 6 more sleeves, 500.00 rods, new 800.00 Pistons, 150.00 rings, an "I fckin forgot how expensive" Australian cylinder head full of Chevy spec'd aftermarket junk, ..another cam from Australia, lifters for a 460, a crank that needed this mod, or that mod, a timing chain that fits some Toyota.
Yeah,.....If that's not moronic, I don't know what is.....stupid me,....thinking maybe I'd tame it down,...enjoy the visceral experience of a roller cammed, individual throttle bodied port injected, N/A combo that isn't on a path to self destruction...
Like a newt?
I appreciate the help. Thank you for that.You trailed off before finishing your sentence, but I got it for you.
Hey, dropping one project to start another is normal in our world. And me going bigger than planned with my car is also normal. Rebuilding an engine to handle boost, and installing water/meth just to go N/A a week later.... Hell your current rings probably would have been fine without the turbo. Just sayin, ya soft skinned lizard.
PS, I am impressed you remember my chain of vehicles back to the '86, and surprised no scrapped hoods were mentioned!
Like a newt?
Im not really up to speed on my lizard species, but that sounds acceptable, lol.
Mike,
Your dreaming if you think that I6 will make 300 NA. That's 50hp per hole....thats like saying I put good aluminum heads on a 302 with comparable stuff and make 400hp which is nearly impossible unless you wind the piss out of it. Other disadvantages, your smaller CID then the compariable 302. You have a cylinder head that is head and shoulders above stock, but it is a far cry from the latest Windsor SBF technology. Your also on a smaller bore which is effecting air flow, which ultimately affects efficiency.
IMO even with the turbo your only making mid to high 3's for HP. The Torque that is what you are feeling and that is the big number between 400-500 ft lbs which is long and flat and starts out low.
Scott
I wont know that till I get the pistons out...and......Yes,...the garage is now truly "bloodied".Breaking in that new garage properly there Mike
What did you find out about the rings?
