Progress Thread Project: Buried Under A Mountain Of Snow Black Hole Money Pit.
Then tabs are welded too close together on the cross mount and I had to have the spacers turned down
The tabs on the cross bar are pointed up on one side other side points down
Tabs are shifted over about a 1/4 to the passenger side
The bar is welded to the plates a bit lower on the driver side
So we are cutting the cross bar off the plates making it square then have to cut the mounts off the rear and weld the new ones on. Which I went with the TRZ style that has the billet block in the center vs the plates. This way we don't have to grind the axles tubes perfectly flush
Reactions: A5literMan
Funny how you rebuild a car, paint, engine and all the work that goes into it and the door handle breaks, don't do nothin to a car, like mine, and the handle lasts forever :doh:
I have a friend (I know thats hard to belive) and since painting it has put two door handels on it.
Reactions: srtthis
got that mounted... gotta borrow a block from a buddy of mine to use as a dummy block so i can make the rest of the steering shaft.
Reactions: RaggedGT
