Quite, time for Jeopardy
Everyday I keep looking in, and every day I keep saying the same thing..
I'm glad its you doing all of that, and not me.
I cannot imagine the grinding that is gonna take place...:nonono:
Truthfully, I’m not intending to grind all of them. Just the ones that need it for any fitment issues.
They’ll have a nice layer of dynamat going over them anyhow.
I'm almost out of argon:nonono:.
I started welding the right rear since I new it would be a little bit of a pita. The original rear floor pan metal had pitting in it there.
That went better than expected, so I went down the right rocker too. It was nice toward the end since I can now crawl onto the floor to weld. The right side took longer than the left side. The inner rocker metal was very wavey. The pan comes up 3/4" from the bottom of the pinch weld, so about every three welds I'd measure, beat the metal flat against the rocker, measure again and weld.
I had to take a break at that stage because I'm sweating so profusely. I had to come in and put a dry shirt on. I'm going to attempt to get the trans tunnel ends welded up next, if the god of argon grants me about another twenty spot welds, that is.:chin
