The floor took about 2/3 of a quart.How much POR15 did that take...asking for a friend.
Also prep was red scotch brite and wax/grease remover?
I think I've asked this question before and you've answered it: what do you use for wax and grease removal?The floor took about 2/3 of a quart.
I sanded the real rough areas with 80 grit and a DA. Red scotchbrite for the rest.
After I blew it out I wax and grease removed.
Wax and grease remover.I think I've asked this question before and you've answered it: what do you use for wax and grease removal?
Dave!!! Mike like synecism in your answers..that deserves a thumb up.Wax and grease remover.
Dave, I think you went right past perfectionist and straight to Scott-level OCD!! I never thought I would say floorpans look beautiful but.....those floorpans look BEAUTIFUL!!So I broke out my little compressor and my 3" DA and some 80 grit sandpaper and went to sanding. Predominantly the rocker panels, but also the rusted areas on the lower firewall where it meets up to the floorpan.
I also used red scotchbrites to scuff the other areas I intended to coat, including the whole floorpan.
I took some wax and grease remover and cleaned everything up after I blew most of the dust out.
Then I got out the POR15 and a little 4" foam roller and the cheapest paint brush I could buy and went to town.
That's it for the day. I did clean the weld areas on the undercarriage too.
Tomorrow I'll stop by our local welding supply store and get a new can of argon so I can get the cross brace.
Lol, thanks Craig.Dave, I think you went right past perfectionist and straight to Scott-level OCD!! I never thought I would say floorpans look beautiful but.....those floorpans look BEAUTIFUL!!![]()
