It's not that difficult guys. The hardest part so far has been cleaning those nasty 1x1 tubes before I use them! It's one of the easier mods I've done so far.
If I didn't have to clean the tubing, I would probably be completely done with the driver's side. I just have the portion done in front of the MM seat brace. I still have to do a couple verticals and a couple diagonals behind the brace.
Now when I say completely done, I mean done with the initial fabrication of the system. If you look in the pictures there are only simple tack welds on the sfc's and the rocker pinch weld.
When I'm done fabricating the side I'll cut the welds on the pinch weld and sfc's area and drop the ladder system out as a unit. Then I'll do a prettier weld around each tube end.
Then I'll put it all back in and do as much of a perimeter weld around the attaching points as I can. As you can see in the picture I can go a little way over the top of the sfc's welding area.
I'll do my usual 2" spot welds along the pinch weld and am even thinking about doing a dozen or so spotwelds along the edge of the floorpan. I'm not overly sure of that, i may stitch weld instead. We'll both know when I do it.
Before it goes back in I will seam seal along the floorpan and rocker on the underneath side.
EDIT: Thanks Mike for having done this before me, it's easier to copy than to create!
