1988 turbo 331 TW heads mspnp2
Ok...so...I forgot to update this thread. The car is now starting and running again. My cranking PW was way off ( due to base tune I loaded from MS when I first got MSPNP2 ) causing the car to flood on cold start. Talked to Steve and changed plugs and loaded necessary corrections. Project is kind of stalled at the moment. Gotta feel this car payment for a couple months to smooth out my finances. Lol
Dusty starts up every time with a prime and a crank. I'll post the updated tune and log as soon as I can.
Reactions: stanglx2002
finally have tags on Dusty. Took it out and data logged the drive. Hopefully, you guys can see a little more. This is the tune file I'm currently using. Here's a data log
I tryed to change the name but when I extracted it from a zip file it changed to this. smh
When you and Steve go for a drive in that 2 mile section-ima request the GoPro-also goes with you :D
I'm trying to get my much better half to be a camera woman tomorrow. We're supposed to get some bad rain in the am. but it's supposed to clear up until about 5...and almost 80 degrees.
Reactions: RaggedGT
Every time someone says Ride Along, this is what I am thinking.
Got some time to get a real log done. The tune 4.0.2 has my idle surging a bit. Didn't get into any boost. The first rpm hold was in second gear....then I had to get on a main stretch. Pulled up to a stop sign and had to work my way up to hold 4th at around 2k. Couldn't be out there holding traffic up. Turned around and tried to do the same thing on the way back. Had to hit the gas a little bit to get out in traffic.
Tomorrow I'll be home around 630...I know you're not off till later....but my headlights work.
Lol I will text you tomorrow and let you know, I spent my time tonight cleaning up some small idle quarks and restart fuel on a dart347. I think I can get the stuff worked out much faster 'in person'.. one night this week is an option.
Reactions: 90sickfox
Ok...so...I have a big problem. During a datalog i saw my WB must have lost connection or something. Reading was at 8.4+
Ofcoarse, I didn't look at my wideband before doing this.
That's 162.3kpa or 9psi. I hit that magic wall around 5k and see that the fuel PW dropped out.
Im going to go in and see what my rev limit fuel cut is set to. I guess I'll also have to figure out why my WB glitched out. You can see that shortly after that it came back online.
