Progress Thread Finally got my first Fox Body - 1988 GT
Hey Dude, did you over tighten it?
Yeah looks like rear main seal leak, oil pan gasket leak, oil level sensor leak, both oil pan drain plugs leaking.
All pretty common leaks in these cars or any car of this age.
Like someone already mentioned spray everything down with brake cleaner first and try to get a better idea of
exactly what's leaking.
Just FYI...
To fix the rear main you'll need to pull the transmission/clutch , remove and replace rear main seal.
To fix the oil pan gasket....well you could pull the engine making it easy to access the pan/gasket
or......
Pull upper intake, unbolt motor mounts, jack engine up as high as it will go,
support engine , unbolt pan let it rest on K member, reach up into pan and drop oil pump
and pick-up in pan, fight the pan out of the K member , install gasket and reverse order.
I've done it the second way twice and it's a PIA !!
40’s were Dronemasters on my car, and not being able to talk with someone or really hear the Pioneer stereo were problems.
A high flow BBK cat X pipe and Super Turbo mufflers is mean at idle, but does not require ear plugs on the highway.
I’d get that surface rust neutralized and sealed now before it becomes structural. Is it near where the battery could have leaked on your model? The rail and tower are structural on the unibody.
Baking soda and water will take care of the acid, then a wire brush clean up, Rusoleum Rusty Metal Primer and a good top coat will do a good job, even on a budget. Then make sure the battery tray is not cracked in case the battery leaks again.
The exhaust pipe looks like it got a muffler bandage applied to it. That’s a temporary fix. If there is a hole, and a bad fix if it is splicing pipes together.
Man, based on some previous google/youtube searches, everyone seemed to praise the flowmaster 40 series as the ultimate exhaust sound on the pushrod 5.0. I guess I'll have to look at some other options, haha.
Thanks for the link. Those wave tubes are interesting, never seen anything like that before.
Reactions: DudeStang
Something to do with emissions/catalytic converters perhaps?
No, it's was one of the hangers from the stock exhaust.
The replacement mid-pipe most likely didn't have provisions for hangers in that spot,
previous owner must have not been able to remove them so they just cut them.
My aftermarket X pipe doesn't have those hangers either, no big deal.
Just FYI...
or......
Oh man...The oil pan gasket sounds like a nightmare. I watched BREW2L’s video on doing that without lifting the engine and it doesn’t look pleasant...
Definitely plan to spend some time underneath the car doing the cleaning up when the weather gets a little bit warmer. Thanks for your inputs.
Per some earlier recommendations in this thread I started using a wire brush extension on my drill to remove some of the rust. Still need some more work but my plan is to keep doing that and eventually use something to paint over it/seal it. Thanks for the more specific recs on cleaning and the battery tray. It didn’t look like it had any cracks when I replaced the battery but will double check and probably at least get replacement hardware.
my radio sucks for reseption, I play cds most of the time anyway.
I just have the Lil Wayne CD the seller left in the car but haven't driven the fox on long enough trips to really need anything additional to listen to. :D
Forgot to mention this the other day....when I took the car for a short spin around the neighborhood, I pressed the horn pad and figured out that the horn I had connected was definitely the high pitch horn, lol. It sounded pretty sad and pathetic without the garage walls helping it echo. I'm going to need to find a way to get the other horn attached too at some point.
