Help with TrickFlow Top End Kit
Lamriokart
12
SOCAL
Hey all I've recently purchased the Trickflow Top End Kit: https://www.summitracing.com/parts/tfs-k514-360350b and just had some questions for those that have installed the kit before. Is there anything else I should buy other than the timing cover gaskets and assembly lube or does this kit come with just about everything I need? I've also decided on 24lb injectors and was wondering if a 190 lph fuel pump is a good match for it along with a 70mm throttlebody. Will be my first time workings with cylinder heads/cam so any advice is greatly appreciated it. Thanks.
You will need the matching meter for the injectors.
Me personally, i like a 155lph pump.
190 is more than you need for a hci setup and less than you need for a supercharger, so I really don't see the purpose in a 190.
The 70 is fine.
I must be out the maf game, I don't even recognize that meter, lol.
I always used an 80mm.
Choice of TB? That's easy, accufab, I just wish they all weren't polished...
Basically back in the day when pro-m had their falling out they split up and one owner opened up pmas while the other kept pro-m. It's a good meter i've used them in two of my cars so far and are a good bit cheaper directly than through lmr etc
I agree accufab is top notch
I was around for pretty much all the meter companies (and drama), just never saw that shape before.
I think I had at least 8 different ones.
Even one I wish I never sold, a pro M with a dial on it for a bunch of different injectors.
haha yeah there sure was some drama... the best was the UPR and Granatelli drama though
