Guess My H P !!! - The Dyno & 1/4 Mile Time Thread
Finally hitting the dyno in the AM
408w
AFR205
10.75:1 compression
Super Vic
Holley Sniper
1.75 Long Tube BBK
2.5" bbk catted H-pipe
Dynomax supertubo mufflers
CAM .608 lift 236/244 @.050 112 Separation 109 centerline
Tremec Magnum
3.73 gears
Finally made it today swapped the H pipe to off road X pipe. Made 448 to the wheels. Not bad for a pump gas street car to take the kids for ice cream.
  • Hell Yeah!
Reactions: General karthief
What transmission are you running? That's 30% loss, seems high
c4 transmission. my stall is not right. I had a shop rebuild it and it should be a 3,800-4,000. they charged me 700.00 to rebuild and re-stall. it was stalling about 3,000 before so I just wanted to raise it a little. it only stalls to about 2,500 - 2,700 now. I called and told them and the guy said some time we don't get it right bring it in and we will try again and hug up on me. its a lot of work to pull it out. my camshaft rpm range is 4,200-7,200 but I shift it at 6,500. this calculator online says with the hp and weight it best pass should be a 10.76. so its about a second slower than it should be
These are from a few years ago, the last time I ran the car.
ETA: just wanted to update. I sold the car a couple months ago, new owner had it dyno'd and it put down 277 RWHP. Seems pretty consistent with the time/MPH
86 GT hatch, 5.0/5-speed
stock 89 shortblock (re-ring and new bearings)
96 explorer GT40 heads -F3ZE casting- with mild port and polish (cleaned up bowls, smoothed transition etc.) with Trick Flow springs
stock rockers
9333pt felpro head gaskets
TFS-1 Camshaft installed dot to dot
Edelbrock Performer EFI intake
65mm explorer TB
67mm FMS egr spacer
Stock 55mm MAF
19 lb 4hole injectors
155lph walbro pump
Cold air intake with K&N conical filter in inner fender(at time of run- stock airbox now)
Flowtech shorty headers, 1 5/8" primaries, 2.5" ball flange
off-road 2.5" H-pipe
Flowmaster 2.5" cat back
A9L computer
17* initial timing
Taurus 3.8 electric fan ( with 3G upgrade)
Stock T-5 (3.35 first gear)
8.8" with 3.73 gears and carbon fiber clutches
225/55/16 falken street tires on pony wheels.
Car should be close to stock weight, has full interior, A/C, P/S, no smog, stock sway bars are on and hooked up, stock suspension with replacement shocks/struts.
Runs were with 1/2 tank fuel and 215lb driver
Temp was mid 60's, elevation of track around 45' above sea level.
13.773 @ 101.463 mph
13.888 @ 101.574 mph
Last year I posted a dyno and times with a stock motor and Holley terminator x. This year she got a bit of an overhaul, BUT the dyno was at 5280 feet of elevation vs the previous year at 800 feet of elevation.
Either way, pleasantly surprised with her.
All the same modifications as previously posted with:
Edelbrock intake manifold
TF 170 53cc 11r heads
AFM N41 cam
1.6 TF RR
Went to the Antique Drags this weekend so now I can post here.
62 Falcon 2dr 2790lbs with me in it
302 roller from an 80s Town car with dished low compression stock pistons
E4 heads, stock HO cam, Explorer intake, 19lb injectors, iron exhaust manifolds into 2" single
4R70W with a Quick2 controller.
8" trac lok with 3.00 gears spinning 195/60/14s.
10.5s @ 70ish consistently in the 1/8 mile
Made everybody else look fast
89 stock short block
AFR 165 Renegade heads
XE266HR cam
Trick Flow Street Burner intake
24# injectors
75mm TB
75MM MAF
1.7 roller rockers
BBK shorty headers
BBK off-road X-pipe with Flowmaster 40 series
3.73 gears
Lowered with stiff suspension
Stock rebuilt T-5
312 whp 342 tq
I haven't had it on a track yet, but would like to see mid 12s at least.
AFM N41 cam
1.6 TF RR
That's cool, our numbers are practically identical.
91 LX conv, 5.0, 5-spd, 3.73 gear set
Set-up:
  • 30 over 302
  • Aluminum Trick Flow Heads and Upper/Lower Intakes
  • 70mm EdleBrock Throttle Body
  • 80mm Pro-M Mass Air Meter
  • 24|b Injectors
  • MAC shorty headers
  • 2.5" X-pipe (no cats) and Flowmasters
  • Aftermarket chip
251 whp / 266 tq (Mustang Dynamometer)
