Tougher than building the working prototype.Thanks! Kurtis does most of that work but it's a time consuming affair for sure
That's for sure. Its easy to make something work one-time by one person than it is to make something that anyone can do it repeatable 100% of the time.Tougher than building the working prototype.![]()
Why not just install a resistor in the harness, like the one off the back of the OEM cluster? Thats all I did on my SN.As far as alternator charging what are your guys opinions and thoughts on this product? I did the 3g conversion years ago.
3G Regulator Self-Exciting (985204SE)
American Muscle Late Model Restoration LMR PA Performance Alternator Starter Ford Jeep Dodge Ram 5.9 Cummins Diesel 6.7 Cummins Diesel F150 American Truck SR Performance Extreme Terrain Mustang Cobra Bullit Shelby GT500 Alterantor Starter Ford SVE CJ Pony Parts Pure Diesel Power Destrokedwww.paperformance.com
I am going to need some more context for these questions.Have a few questions, if I may?
Running a Pimpxs with what I assume is the 2v of the DDefi dash. And love it
1Q. In the pictures I show the jump wire going from JP29 to JP26, but I’m unsure on what side( left or right) of JP26 do I put the jumper wire?
2Q. I’m using the internal baro of the Pimpxs so the jumper is on 2-3 leaving 1 open, with this affect the outcome?
3Q. I am running a spartan wideband on each bank. JP12 is my driver side wideband, what would you recommend to do?
Thank you in advance
Has anyone made a dash that looks like the stock foxbody gauges?
I was referring to the dashboard in TS, like for the digital dash.LMR sells a set made by digital Dakota
I’m sure they could make a custom one for youHas anyone made a dash that looks like the stock foxbody gauges?
An HD rendering of the OEM Gauges would be pretty sweet. The ability to customize the arrangement of gauges as well as the limits of each one would be pretty sweet too.Has anyone made a dash that looks like the stock foxbody gauges?
), you could make any gauge face you can think of. There currently is not an option to use an input to handle User Actions within TunerStudio. This has to be manually done by like said above touchscreen swipe or using a keyboard/mouse to change between the tabs. If TunerStudio provides this option we will for sure be using it.I love the idea of a stock cluster dash. Just installing my pro dash right now so I don’t even know where to begin in regards to making custom dashes. I would be willing to donate some money for the development of one. I was also wondering if it is possible to configure an input to switch between different dashes?
You have done a pretty good job on your dashboard. I have attached some turn signal and high beam icons for you. You can also use indicators with no text and black background to cover anything that you don't want to see, but you will have to remove the needle and overlay another gauge on top to hide everything. If you need some help just let me know.Came up with this. Needs turn signals and high beam still
