Hey fellas
I have a 1994 Mustang Cobra with the following setup.
BBK CAI
BBK Throttle Body
Stock upper and lower cobra intake.
AFR 165cc Heads.
Trickflow Stage 2 Cam.
Stock bottom end.
4.10 Gears.
$$$Rwhp - $$$ft/lbs
The AFR website has an intake manifold recommendation being the Performer or Performer RPM intake manifold. I didn’t immediately fall into one of those because I am not sure that info is up to date. It hasn’t changed since 2019 when I bought the heads. This car is only street driven, but everything I do is preparing it to be the best it can be as a naturally aspirated 302. $1500 budget for the intake. If I left out any relevant info just let me know in the comments.
Best Regards,
Zachary
BBK CAI
BBK Throttle Body
AFR 165cc Heads.
Stock bottom end.
4.10 Gears.
$$$Rwhp - $$$ft/lbs
Best Regards,
Zachary
Unless there is too much torque? Currently the car Dyno's at 285hp / 323tq at the motor. I guess the perfect outcome for NA would be like 300hp / 350tq if that is within the realm of possibilities for a NA 302. Also, could you educate me on the "RPM range differences" you mentioned? I am new and have been doing all of this by myself with the help of these forums and YouTube the past 4 years. (Unless you meant between the different manifolds and their availability, then disregard.)
