You will need to install this piece which you may already have but it’s hard to tell:
Have a cracked or leaking center brake hose on the rear of your 1986-95 Mustang? Replace it with this high quality, direct fit replacement!
lmr.com
Then you need this piece:
Watch the video on how this installs. It’s at the bottom of the LMR page.
Then you will need to reroute the rear brake line from running all the way down the passenger side to half way down and then transition to in the driveshaft tunnel to connect to the piece in the link directly above.
