What year is this car?
Not questioning the build sheet.1985
Now to be fair I didnt run any of the info off that build sheet. So I guess I should say I found a build sheet, that could be for this 85 GT
A buddy had a cheap set of gages and it didnt move at all, low or high
Plus it is oem stuff over 30 years old so I can see putting any money into repairing it.
Only if the car was not equipped with A/C from the factory.I thought the 4-eye cars can go through the glovebox to do heater core?
I can decode a lot of it, if you want.I didnt run any of the info off that build sheet.
The heater core was bypassed when I got the car so I assume I will need to pull the dash to do a heater core replacement,I have not done this before and I can say I am not looking forward to it. Is there a preferred heater core to use? I don't want to do this again.
And yes, I would do the Cobra booster. It's 2x the assist of the fox booster and the brake system was designed with this in mind.
As for ac...have you tossed pressure guages on to see where you are at?
