Posted: Sun Dec 17, 2006 10:18 pm Post subject: 1989 MUSTANG GT STREET/STRIP ROLLING CHASSIS
The time has come to sell my 1989 GT Mustang
The car has been 10.83 @ 124 MPH with a 1.44 60 FT time on a true 10 inch tire. This was done with a N/A 308.
I would like to sell this car as a rolling chassis, to save the motor for a future project. This car works very well, I have time strips and video of the car to prove. Here is a list of what the roller will come with.
The car could be used for street or strip, still has lights, heat etc..
and even has a new heater core installed.
SUSPENSION
Full D/D K Member kit
Tubular A Arms
Coil over 175-14 springs
Lakewood 90/10 struts
Caster camber plates
Long Studs
South Side Sub Frame Connectors
South Side rear lower torque boxes(adjustible)
Wild Rides Upper Battle Boxes
South Side Upper Control Arms
Stock Lower control Arms which have been boxed,
with polyeurothane bushings, also have south side lowers
available that need a new bushing kit ($69.00 for kit to correct)
Lakewood 50/50 rear shocks
Rear Differential
8.8 Rear with axles tubes professionally welded
T/A Cover
Moser 31 spline axles with c-clip eliminators
screw in long studs
Moser 31 Spline Spool
Your Choice of gears, has 513 Gears Now
have 331 to 513 gears available and will install
FUEL SYSTEM
Car is originally fuel injected
It is set up for carb now
Sumped Tank
Fram external hi performance filter
Holley Blue Pump
Holley Fuel Press Regulator
- 8 Braided Steel Line back to front
(Also have the Fuel Injection, harness,sensors, a9l computer
distributor and stock manifolds if requested).
Body
The car is red with red ground effects
Four inch Cervinis Cowl Hood
85 Gt tail Lights or original GT tail lights
Extra Front@ rear bumper and ground effect parts
Interior
Factory front and rear seats
rear seat has been removed, but is included
extra carpet provided also
8 Point S/W roll bar
two 2 5/8 autometer fuel press guages
one is in hood, one in engine bay
10 inch autometer monster tach w. shift light
Misc
turbine wheels
battery relocated to trunk in NHRA certified sealed box with vent
and cut off switch
drive shaft loop
adjustible firewall clutch cable and quadrant
asking $3500.00 but will negotiate if fuel system is not wanted etc...
will not part out vehicle , looking to sell as a roller
this car is ready for your engine and transmission
buy it rolling today, go racing tommorow!!!!
Also have a t-5 pro shifted transmission , alloy gear, liberty pro shifted,
335 1st gear ratio ...asking $800.00
Please feel free to call with any questions
609-238-0170
email - [email protected]
_________________
SUSPENSION
Tubular A Arms
Long Studs
Rear Differential
T/A Cover
screw in long studs
FUEL SYSTEM
Sumped Tank
Holley Blue Pump
Body
Interior
Misc
turbine wheels
and cut off switch
drive shaft loop
609-238-0170
_________________
This just beats all I have seen. Usually so quick with the locks. I am worried. Where are the mods. Its a free for all pals
