1993 LX 5.0 dies after ignition parts replacement
  • Thread starter Thread starter Warhorse85
  • Start date Start date Aug 16, 2025
  • 3
  • 4
  • 5
  • 6
  • 7
First Prev 3 of 7 Next Last
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Aug 22, 2025
#41
  • Aug 22, 2025
  • #41
When you say, "no codes"; what does that mean exactly?
Did you get the "no codes" code?
W
Warhorse85
66
18
18
Aug 22, 2025
#42
  • Aug 22, 2025
  • #42
I have a ford specific code reader and there are no codes present
Mindseye007
10 years still blowing strong
5 Year Member
Oct 21, 2020
586
137
63
ontario
Aug 22, 2025
#43
  • Aug 22, 2025
  • #43
Warhorse85 said:
Has fuel pressure, new tfi, coil, maf, egr, cap rotor, plugs and wires. Crank/no start
Your car is an automatic so this TFI is made for a foxbody 5.0 with an Automatic trans. It's a Heavy Duty Version from Rockauto...
More Information for WAI GLOBAL FM425HD
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Aug 22, 2025
#44
  • Aug 22, 2025
  • #44
This is not good. You should get a code 11 on KEOR and KOEO. Code 11 = PASS
Reactions: Mindseye007
W
Warhorse85
66
18
18
Aug 22, 2025
#45
  • Aug 22, 2025
  • #45
I am not buying another TFI. I've already bought 2 in the past week
W
Warhorse85
66
18
18
Aug 22, 2025
#46
  • Aug 22, 2025
  • #46
So what would that mean?
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Aug 22, 2025
#47
  • Aug 22, 2025
  • #47
That means you should ensure power and ground for the EEC. If you have both, then you need to get yours repaired or swap it with a good one.
W
Warhorse85
66
18
18
Aug 22, 2025
#48
  • Aug 22, 2025
  • #48
Actually Iied, there was a code that related to the smog pump. I deleted it a few years ago.
AeroCoupe
6,117
4,212
183
Claremore, OK
Aug 22, 2025
#49
  • Aug 22, 2025
  • #49
What it means is when you perform the KOEO and the the KOER tests you should get an 11 (which means the KOEO test passed) followed by a 10 (break between tests) and another 11 (which means the KOER test passed). This means no codes are present. If you get codes then diagnose and make repairs. If they are present from missing equipment then you are good to go.
Remember, this ECU is old so it’s first in first out. If you have codes and make repairs then clear the ECU. Take the car out and drive it to get it up to temperature and then drive it for a bit more then pull codes again. Do not be surprised if you get additional codes as they were behind the ones you addressed previously.
With all that being said if you do not get the 11, 10, 11 or codes, 10, 11 or 11 , 10, codes or codes, 11, codes the ECU has a problem.
R
rwordenjr
Advanced Member
Nov 4, 2023
260
363
73
CA
Aug 23, 2025
#50
  • Aug 23, 2025
  • #50
Warhorse85 said:
Replaced TFI, charged battery, tightened terminals on ignition switch connector. Still no start
Did you reset the timing on the car when you installed the new tfi?
Mindseye007
5 Year Member
Oct 21, 2020
586
137
63
ontario
Aug 23, 2025
#51
  • Aug 23, 2025
  • #51
Did you pull the ECU and check the capacitors?
View: https://youtu.be/LeUG0emMs2w?feature=shared
Reactions: Shakerhood
Mindseye007
5 Year Member
Oct 21, 2020
586
137
63
ontario
Aug 23, 2025
#52
  • Aug 23, 2025
  • #52
I think the 2 you bought are probally cooked buy that TFI testor off ebay and see.
W
Warhorse85
66
18
18
Aug 23, 2025
#53
  • Aug 23, 2025
  • #53
What I meant was, I bought 2 already. I just installed the second new one and still no start
AeroCoupe
6,117
4,212
183
Claremore, OK
Aug 23, 2025
#54
  • Aug 23, 2025
  • #54
Can you do a quick recap of where you are at right now? Lots of moving parts and I think we are missing something.
W
Warhorse85
66
18
18
Aug 23, 2025
#55
  • Aug 23, 2025
  • #55
So I replaced the TFI for a second time last night, still cranks with no start. Charged battery overnight and reset ECM this morning. Checked for codes and got 85, 10, 15. Tried to start it and still cranks with no start. Checked codes again and got 10, 85, 11 in those orders according to the scanner
AeroCoupe
6,117
4,212
183
Claremore, OK
Aug 23, 2025
#56
  • Aug 23, 2025
  • #56
Okay here are the codes:
Code 10 - Separator between KOEO and KOER tests
Code 11 - Test Passed.
Code 15 - No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
This can be from an aftermarket chip plugged into the ECU but you have stated that you do not have one. I would start by making sure you are getting a constant 12V+ to the ECU. If that is confirmed then my guess is that the ECU has problems internally.
https://stangnet.com/mustang-forums/threads/obd-1-code-15.903058/post-9111873.
Code 85 - Canister Purge solenoid failure
Do you have a charcoal canister and purge solenoid? Is the solenoid connected to the wiring harness? Also, walked away from the computer and then remembered that you can get a Code 15 if you disconnected the battery at some point and have not cleared the codes since then. Really easy way to clear the codes if your code scanner does not have the ability to do it is as follows:
Post in thread '1988 GT - Clearing codes'
Apr 26, 2007
Easy way to clear codes: connect the jumper wire up like you are going to dump the codes. Then turn the key to Run and when the test light or Check Engine Light starts to flash, disconnect the jumper. This clears the stored codes but does not erase the adaptive settings that the computer "learned".
  • jrichker
W
Warhorse85
66
18
18
Aug 23, 2025
#57
  • Aug 23, 2025
  • #57
Apr 26, 2007
  • jrichker
I removed the smog pump a few years ago so there are some electrical connections that are disconnected. I'm assuming the constant 12v to ECU is all the time regardless if the key is on or off, correct? And whereabouts would I check for constant 12v at the ECM? Also to add, the ECM power relay does activate when key is turned on
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Aug 23, 2025
#58
  • Aug 23, 2025
  • #58
Code 15 is common for ECUs that have had power interruptions.
You've been poking, prodding, and testing so, I wouldn't worry too awful much about the code 15 right away.
So, there [are] codes Color me amazed after the 1.21 Giga-Million times I've asked people for codes and heard, "none".
It doesn't guarantee that the ECU is [good] but it does say that it is alive at the very least.
Reactions: General karthief
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
Aug 23, 2025
#59
  • Aug 23, 2025
  • #59
Turn the key to the [On] position and check for power at pin 1 of the ECU.
Crank the car and ensure you still have 9.6+ volts during cranking.
AeroCoupe
6,117
4,212
183
Claremore, OK
Aug 23, 2025
#60
  • Aug 23, 2025
  • #60
Should also have 12V+ on Pin 1 with the key off.
  • 3
  • 4
  • 5
  • 6
  • 7
W
  • Locked
Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Warhorse85
  • Aug 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2025
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
