Hi Mike,THANKS for the feed back!! I WILL keep that in mind,Thanks!!!Hey Just viewing your rides,that Suzuki sounds "HOT"!!!But Dude,A Volvo???????????Michael Yount said:willys - glad you like it. Be careful of the lure of the 'cam'. If your motor is mostly stock there are very few off the shelf cams that will actually help overall performance. Most all of the common off the shelf cams are designed to work with aftermarket heads, intakes and exhaust systems. Even then, they make less bottom end torque than the stock set up does. Put one of those in a stock engine, and it will absolutely kill the bottom end performance - which is what you like so much about yours.
If it ain't broke, don't fix it. Sounds like you've got it running great. Be REALLY careful about the cam decision.
