Hey everyone,
I am thinking about picking up a 390 from a 1963 Galaxie and swapping it into my 'stang. The 390 comes with an intake, cast-iron exhaust manifolds (from the Galaxie--might fit??), an alternator, dsitrtibutor, and starter.
My car is '68 coupe with a 302 and a 4-speed toploader. The 4spd was oringinally from a Torino with a 390, and was recently rebuilt. The 302 was from a 1971 Torino and has a 500 cfm Edelbrock carb. The rear end is an 8" with standard 2.79s. I've manual discs up front and over-size drums in the rear. I'm also using Ron Morris adjustable engine mounts.
Questions: What would I need to make the swap? Would I need new engine mounts? Would the 500 cfm Edelbrock be a bad choice with the 390? Would the rear end hold up? And the most challenging... what bell housing would I use (I don't see anything in catalogs that looks right).
I've heard different takes on the '68 shock towers and running a 390. Some folks say no metal work is required, others say Ford added addtional bracing and reworked the towers for the 390. I thought the 390 would fit without metal work.
I really appreciate any advice! Thanks!!
