5 things needed to run 12's n/a
Uptown Gambler
Does anyone remember Bill's ( :hail2: ) thread about the five things needed to run 12's n/a? I found the archive (#18904 I think), but the info. was not there--only the replies. Did anyone happen to save it, or know of a similar updated thread by Bill? ( :hail2: )
As a remembering reference, it was the sticky where some kid did not believe Bill ( :hail2: ) and kept arguing with him. Finally Bill ( :hail2: ) slapped a magazine article about his car running 12's n/a. :rlaugh: It was funnier than 'ell.
md is down right now for me but:
gears(4.10 preferably)
Exhaust(at least a midpipe maybe headers)
minor weight reduction(seats, trunk stuff)
nice tune
slicks
I needed a plenum and tb and pullies to get there myself on the bone stock susp. I could have done it with less but that was in 1000' DA's
nice tune
slicks
All you really need is gears, slicks and suspension.
not gonna happen without exhaust work and timing. the stock suspension is capable of mid 1.6s with just the addition of lca's, my vert went high 1.6 with nothing more than the sway bar removed and bullitts at all 4 corners on et streets
sorry, I meant with some engine mods. My bad, I wasnt clear. But the suspension mods will do more than the exhaust mods does. You also wont get a good sixty foot time a lot of the T&T nights, especially at the cheapper tracks. The 5 dollar and 10 dollar tracks. They never prep the track on T&T nights.
bill???:shrug:
thats been the foot up my ass since I started going to the strip. Theres not a 1/4 in the entire state, just small mom n pop 1/8 and 1000' tracks. I dont think ive ever experienced track prep :nonono:
Actually.. they do prep the track.. there's been a Nova runnin 5.8 in the 1/8th out there that can't touch 5's without track prep
I told BFI that they didn't prep it, but he corrected me. He explained to me how it works. We just suck, that's all. You have experienced awesome track prep. Last season when I ran my 8.7 1/8th, you went the very next weekend and it was hooking the same.
Hell, even stu and the other guys were hooking the past few weekends. :(
Why do you think they're raising the racing fee?.. They prep the track more and it's costing a tad bit more, so they're going to get their money back. They just spend an assload in the middle of the season last year completely re-doing the track and making those new staging lanes. You should've ran on it before they redid it :nice:
Are you referring to a specific track? I know for a fact my local track does NOT prep the track for T&T nights. They only put some THC(i think) when the guys with slicks run.
So why didn't anyone just put the content in here? :shrug:
Bill Putnam said:
Five Components to a 12 second NA GT
Before reading on I just want to say that this is basically geared towards drag racers not your average enthusiast looking for 12s on street tires with no real changes to the car. Not that it can’t be applied to someone looking for that but this is geared more towards the people out there looking for 12s and willing to work for it.
1.) Power – If you listen to some old school drag racers they may say you need at least 300+RWHP to hit 12’s in most cars. In some heavier cars that may be true but fact is suspensions are more refined these days and cars don’t weight 4,000 lbs. Most PI headed cars will hit the 245-255RWHP mark with basic mods (Pulleys, Timing Adjuster or chip, O/R H or X, K&N or other type of high flow filter and although not a power mod…gears 4.10s or 4.30s). For a bolt on GT this is enough power to get the car into the 12s after you follow the other steps. Keep in mind more power will make it easier to reach your goal or help offset more weight (see next section) but it can be done with less.
2.) Weight - You basic 5 speed coupe without driver weights 3250lbs. So with an average driver weighing about 180lbs that puts your race weight at 3430lbs. At that weight and a power to weight ratio of .075 you would need 258RWHP to hit 12’s. Power to weight is the power of your car (rear wheel) divided by race weight of the car. Using my car when I broke into the 12’s first time I was making 246RWHP and had a race weight of 3250lb, which worked out to a .075 power to weight ratio or .075RWHP per pound of the car. From what I’ve seen a car can get into the 12s with a .075 to .080 P/W ratio. So if your race weight is 3430lbs then 3430 * .075 = 257.25RWHP. As long as you keep this ratio in the .075 to .080 range you are fine plus keep in mind you can drop weight instead of adding power. An example of this is a car with a 3000lb race weight could break into the 12s with 225RWHP (close to stock power on a GT).
Now I’m sure some of you are asking about weight reduction. Basic weight reduction would be rear seat delete, removal of spare tire, jack, tire iron…these would knock a good 70-80lbs from the car. Add a set of welds or light weight race wheels and you are looking at another 60-80lbs. For more information about specific weights and more ideas look here… http://users.adelphia.net/~mustang-9...0Reduction.htm
3.) Suspension - I feel that this component has the most leeway so to speak. I’ve seen near stock suspension cars get good weight transfer. I honestly believe a car that meets the other requirements could hit 12s on the stock suspension. However those of you that want to get an edge should read on. First thing I would do is look at springs since most of us want a better stance but still want weight transfer. For that look at fox body 4cyl front springs I usually look to the junkyards for these but most buy stock replacements at a local shop (avoid Moog brand though they are taller than stock specs). For the rear end I go with fox body v8 rear springs cut anywhere from a ¼ to 1 coil to level out the car. Just keep in mind that it’s easier to cut too little than too much spring.
Next I would highly recommend a pair of sub-frame connectors welded in to tie the chassis together. Hard launches on slicks will twist the body and this will help keep it straight. Last piece to really help out is struts I went with Lakewoods because they are readily available and affordable but adjustables can be used as well if you have the budget for them. 70/30s and 90/10’s both work well and I stick with fox body specific struts since the car is lowered. Fox body specific springs are ¾” shorter than stock SN-95 springs so the lower fox body specific struts are shorter.
4.) Traction – I’ll cut to the chase here and just skip over street tires and drag radials and go right to slicks. Not that it can’t be done on these tires but it will take more power, more patience and much more writing on my part so we’ll stick to slicks. Cars in this weight range and power level only need a 26x8.5x15 ET Drag for traction. It’s close to stock tire height and is more than enough to make our cars hook on the track. A better suspension will result in better 60 foot times but even on stock suspension a good burnout on slicks will not spin unless the track is poorly prepped or fluids are on the track. Some people opt for cheap steel wheels which I don’t necessarily recommend since you are keeping extra weight on the axles. This opens you up for possible breakage so I would go with a weld wheel instead even if it’s a pair of used ones for track only purposes. Regardless a 15x8 with 5 on 4.5 bolt pattern and 5.5 backspacing will fit perfect, or if you insist on a wider tire like a 10” then a 15x10 with 5 on 4.5 bolt pattern and 6.5 backspacing will also work on our cars.
5.) Practice – This is one component that you can’t buy at any store, you can learn it from a text book and you can’t ask your friends about you simply have to get out there. I’m not saying everyone should be like me and hit every test and tune but don’t expect to make one trip and bingo your in the 12’s. I race on slicks for 3 months before hitting my first 12 second pass. Going to slicks alone was a big change that I had to adjust to before I got the hang of and learned to shift better, etc… Take your time, get comfortable in the car and have fun with it. Do that and you’ll achieve your goal.
Now that you know the key components to get into the 12’s you have to keep it all together.  In the above situation I would highly recommend an aftermarket shifter just to help keep the transmission alive longer. The biggest weakness in the above is the differential and axles. Not to say they can’t take some abuse because they can, mine went almost a full year of launches on slicks before breaking. I would look at a set of 31 spline axles and an Eaton or Ford 31 spline differential beefed up to keep the back end in one piece.
Yepp, Centerville Dragway.. Centerville, AR.. 1000ft track :D
I used to work there, also, so that may influence my thoughts about when they do/don't prep the track
