stonecoldtx
Ok... I am back from vacation... I really didnt want to come back
Anyway, I worked on the distributor issue, and here is some other interesting things.
The distributor was in there perfectly. I found TDC, and it was exactly in the spot it needed. The plug wires were ALL wrong, so I pulled all the plugs (platinum) and cleaned them all. Changed out the injectors to a new set I had (verified new, not OLD from the toolbox) and put everything back together. Put a timing light on it and it was at 10 perfectly... no moving around... NOTHING.
I put all back together and it is back to the sluggishness it was at before. NO low end power, popping and using a ton of gas again. The 10degree mark on the distributor matches the mark in the block and matches the marks on the balancer... so I dont believe anything has moved.
I checked the TPS sensor and it was still good. Ran it through the range and it moved properly (went up as the throttle opened). Reset idle with the IAC disconnected and it idles just fine... just not anything partial throttle... falls on its face, but full throttle and it is nice.
I want the car back I drove before I left where it was a real EFI mustang with plenty of low end power....
Anything else I should try at this point? Thanks
It sounds like we still have a problem with the timing; are you sure that the SPOUT is connected?
Also, when you say the 10-degree mark on the distributor, where are you getting that mark from? I don't recall ever seeing any marks of that type on the distributors of these cars.
There is also a possibility that the outer ring on the dampener ring has slipped, which would throw off the timing.
On EFI systems, the ECU tries to control the idle speed using the timing and the IAB motor. However, it relies upon certain assumptions regarding how much air is entering the engine via the TB, so that's why you have to set the idle in the manner I described before--disconnecting the SPOUT connector and the MAF connector, and then setting the idle speed to 550RPM.
Once those are set, and the TP sensor is set to around .95 or .96, if you still have a bog/cough when you give it throttle, you likely have issues elsewhere, such as a vaccuum leak, or maybe even low compression on one cylinder.
There are also the basics . . . rotor in distributor turns counterclockwise, firing order is 1-3-7-2-6-5-4-8, etc.--it wouldn't hurt to check those out while you're at it, just to verify everything is right.
Let us know what you find out . . .
