8.8 rear end in a 65 mustang
jesseboy
im thinking of puting a 8.8 out of like a 98 explorer what i thibm i have to do is just cut one side that is longer and move the spring perchis im takeing it to a shop to have it done then i will do the install i have late modle wheels on the car so im just wonering what other mods i have to do ?
IIRC, when narrowing the long side of an Explorer axle (so that the pinion becomes centered), it will end up being around 59" wide (proper width for 67-68) or two inch two wide on a 65-66, which off course can be compensated with large offset late model wheels. I'm going from memory here, so I'm not sure about the dimensions.
whats the best way to go with the driveshaft?
I don't think anything will bolt right in, but there are a few options for mating the driveshaft to the rear.
1. You can use the stock Explorer flange (same as truck, van and full-size cars) but it has the largest diameter and allows the least tunnel clearance
2. You can swap to a smaller diameter flange like the one used on most Mustang 8.8s. It allows a little more clearance.
3. If you don't like the flanges, you can swap on a conventional rearend yoke from a early 80s truck.
