You want to know what an '03 cobra IRS looks like on a friday night?
@Noobz347 ahhhhhh.
Help me here Dean, does all that mean, ‘Yes’?Everyone talks about what is different, and custom, but rack and pinion suppliers know what is the same. As long as you find the right tie rods, you can modify the track widths to suit common parts.
The Cobra powered rack and pinion steering is based on the 20 and 15:1 power steering unit used since 1968 by Adwest in the United Kigngdon, and its difference between the earlier ones is its rack width, clamping, and its torsion bar diameter.
General info:-
The better Rack and pinion systems have the stiff, 0.210" torsion bar with a ratio similar to the 15:1 ratio used in later 1986 onwards Mustangs. Jaguars, IIRC, are 13.7:1, same as Cam Gears Jensen Interceptor, and FF, and Aston Martin, 2.57 turns to 2.75 turns lock to lock.
The 15:1 Mustangs are 2.25, 2.5, or 2.75 turns lock to lock. The earlier TRW ones 20:1, and 3.1 to 3.25 depnding on ratio, turning circle lock off tanks or rack limiters. Ford basically reworked the steering lock to ensure the later wider 7"to 8" rims didn't hit the suspension parts. Earlier Fox Mustangs had at best, TRX 5.9" rims. Then in 1980, the first 8 or so production McLaren M81's had 15 x 8's and 255/55 HR 15's, but it's width was all done with stock parts because the extension was all on the outside the stock. The wheel offset did it all, and the front and rear tracks were 59.6 and 60", up three inches from the stock 56.6 and 57".
The later Fox 4's and New Edge SN95's went right up to that track width by extending the SRA, IRS and IFS hard pointsoutwards like what was first done in the 1982-1992 Linclons and 1984-1986 SVO's.
The racks themselves were made in the designs infancy by Cam Gears, but were Adwest patents, and even Adwest purchased Burman in 1978, and all that Burman/Cam Gears/StanPart/ Marles/Bendix/ TRW/ Ford brand was just typical white box supplier stuff, so the major French, German and US owned steering companies used the components, and bought the designs or owned the patents. So that's why ZF Germany made Jag, deTomaso and Maserati steering rack with Adwest patents and Cam Gears designs.
Look at any good Pommy Grand Tourer, like the Jag XJ-6, XJ-S, XJ-40, or Aston Martin, Jensen interceptor , or Italian Maserati or power steered Mustang II or Chevrolet Chevette, and you've got the same generic kind of rack and pinion system. They all run Jaguar style torsion bars, 0.190, 0.210, 0.235, 0.250".
As the bar daimeter goes up, the feedback Nemitz diagram relationship changes, and you get more steering "weight". The Feel of the steering is controlled by bump steering curve, the solitidy of the steering box mounting, the steering damper compliance if its rubber or solid, and playing with the rate of power assitance.
Note:-
The best of the last SN95 Mustangs, used 15:1 internal gears, and the same kind of stiff torsion bar the XJR Walkinshaw Jags used, 0.235".
I think it was, you know what Noobz? If I just used that little search thing I could probably have figured it out. I’m an r-tard.
