85 x pipe installation
Just got a xpipe from upr products. When i ordered it, the guy told me that i would not need the double hump crossmember to install. . he said that it would bolt on to the back of the headers straight to the mufflers- turns out the back of the pipe will not fit into my mufflers and i am ditching the factory ones to get a set of 2 chamber flows. we did not bother taking the exhaust apart once we saw this would not work. Is the flowmaster inlet different than the inlet on the factory ones? i also noticed that the passenger side muffler is bigger than the driver side.
i kind of figured that but oh well. i might as well go get a $20 crossmember from the junkyard before we got everything ready to go. i have heard from somebody that the cougar crossmember would work. the back of the pipe to muffler(pipe doesnt fit into factory mufflers)-does anybody have any recommendations?
I believe the stock manifolds on an '85 are an unequal length....as in the collectors end in different spots because the car originally came with a Y pipe....you might want to pick up some '86+ headers from the 'yard while you're there, unless you can afford new headers. My car had a similar problem but i was ditching the stockers anyways so i never really looked into it.
