86 Mystery Mods Progress!
  • Thread starter Thread starter Slobin3d
  • Start date Start date Sep 25, 2017
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
  • 10
First Prev 6 of 10 Next Last
Slobin3d
246
17
38
Nov 13, 2017
#101
  • Nov 13, 2017
  • #101
5.0Droptop said:
Seems to me when I converted my 87 over to mass air with a9P ecu I had to run some wires over to the fuel pump relay.
There's a couple wires that were connected at the computer that run up under the dash into Oblivion I haven't been able to trace, could be the one I need
Slobin3d
246
17
38
Nov 13, 2017
#102
  • Nov 13, 2017
  • #102
So that bundle of wires are the fuel.pump, im not sure what's what other then there is a solid red, solid yellow and what looks to be a tan and green? In the bundle, but the red is constant power to the fuel pump. The PO had T'd it off of what I think is an airbag power wire from the 93 harness.
At least I can move the car again, and it fired right up and idled nice and smooth, so that's good
Reactions: 90sickfox, 5.0Droptop and General karthief
Slobin3d
246
17
38
Nov 13, 2017
#103
  • Nov 13, 2017
  • #103
For the love of all that is holy, please please just buy the MAF adapter kit and follow the instructions, it's soooo much better then a harness swap and mod
Reactions: General karthief
Slobin3d
246
17
38
Nov 13, 2017
#104
  • Nov 13, 2017
  • #104
Sooo. It started and idled great, then as it warmed up it stumbled a couple times then died. After restarting is doing the 1200rpm idle and cuts out at 3k again/still. Which is what started this whole ordeal. I'll pull codes in a bit. Grrr!
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Nov 13, 2017
#105
  • Nov 13, 2017
  • #105
I had the cut out issue once. It might be the tfi moduel. I changed from sd to mass air and had a aftermarket tfi moduel It was causing issues. Just a thought.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Nov 13, 2017
#106
  • Nov 13, 2017
  • #106
Also do you have the correct coil i had after market coil breaking up ignition once. Also the correct plugs for gt40 heads?
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Nov 13, 2017
#107
  • Nov 13, 2017
  • #107
also use your digital meter and check the tps for dead spots.
Slobin3d
246
17
38
Nov 13, 2017
#108
  • Nov 13, 2017
  • #108
I'll have to research the tfi, as far as the coil and plugs, it's an accell coil, and accell 19# injectors. Not sure about the plugs, haven't pulled one yet
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Nov 13, 2017
#109
  • Nov 13, 2017
  • #109
Is it the accel efi coil ?
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Nov 13, 2017
#110
  • Nov 13, 2017
  • #110
Not sure if the plugs are indeed different for the gt40 heads. Just thinking out loud.
Slobin3d
246
17
38
Nov 13, 2017
#111
  • Nov 13, 2017
  • #111
As far as the coil, I'd assume so as it plugged into the efi harness, and matches the injectors, it can be seen in the pictures I posted earlier, as far as the plugs, I believe their the same, but may need gapped different for the hotter coil
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Nov 13, 2017
#112
  • Nov 13, 2017
  • #112
I looked at coil photo. The wire looks burnt in the plug. I know you fixed a lot of wiring already.
Id ohm out the coil make sure its good.
Set the timing to 12* base. That is with spout plug removed.
Check and gap plugs to .052
Check the wires firing order is correct.
Check cap n rotor.
Reactions: General karthief and Slobin3d
Slobin3d
246
17
38
Nov 13, 2017
#113
  • Nov 13, 2017
  • #113
The throttle doesn't cut out if I get into it slowly, or in a 3rd 4th 5th
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Nov 13, 2017
#114
  • Nov 13, 2017
  • #114
Check the things i listed and research the tfi if those things do not fix it. That sounds very much like what my vert did. First time it was a coil issue.
Second time it was after maf conversion. I had an accell billet dizzy with accell tfi that the a9p ecu didnt like. Took awhile to sort it out. Another guy on here was helping me and mentioned the tfi might be the issue.
Slobin3d
246
17
38
Nov 13, 2017
#115
  • Nov 13, 2017
  • #115
Will do
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Nov 13, 2017
#116
  • Nov 13, 2017
  • #116
Have you put a timing light on it and checked timing?
If not id do that as well. Id start at 12* base (with spout out.)
Slobin3d
246
17
38
Nov 13, 2017
#117
  • Nov 13, 2017
  • #117
I have not, I moved cross country and it and a few other tools didn't make it
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Nov 13, 2017
#118
  • Nov 13, 2017
  • #118
You need to start there and move on down the list. It could be the timing is too advanced.
Reactions: Slobin3d
Slobin3d
246
17
38
Nov 13, 2017
#119
  • Nov 13, 2017
  • #119
Could be right, I'll have to see about getting a new one, but there's no audible knocking. So that's good. Lol
Reactions: 5.0Droptop
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Nov 13, 2017
#120
  • Nov 13, 2017
  • #120
So heres my suggestion updated
You must check and set base timing that is imparitive. Id Set the timing to 12* base——>That is with the spout plug removed.
Ohm coil to ensure its within range.
Check that plugs are correct ones and gap plugs to .052
Check that the plug wires firing order is correct.
Check cap n rotor.
inspect plug wires.
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
  • 10
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
