spraying a wet shot below a 175 and at 3k rpm and higher there is hardly an issue with the puddling. That is why a window switch is SO important to make sure you dont spray below 3k rpm.
We have smog stock from the factory/dealer...that tube from the pass. side header is the EGR (smog) tube to the EGR valve, the thing under our alt. is the air pump (smog pump) to the air lines that go to the cats (smog), The hard line tube that goes from head to head on the back of the motor and then goes to the rubber hose is smog as well...
Or did your used car dealer sell you a car with the smog removed?
