96 Problems :(
  • Thread starter Thread starter Travis Hufstetler
  • Start date Start date Apr 24, 2012
T
Travis Hufstetler
  • Apr 24, 2012
Hey, I have a 96 that started as a V6. My mom's husband thought he was cool and put a 5.0 from a 1991 Fox and carbed it. He isn't that smart and now that my mother passed, I now have the car, and a huge headache to tag along. Ok, so it has a 91 5.0, a C4 tranny, and a 96 Cobra rear end. It does not run and I have went through 4 ignition modulestrying to fix it. I have no idea on how he wired it. Whenever I put the wire that leads from the module, to the coil, the wire starts smoking. I am just dumbfounded on what to do any help?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 24, 2012
  • Apr 24, 2012
Is your ignition system still using the EFI TFI module ? Or is it using the DuraSpark distributor and the DuraSpark box and coil?
The old style ignition systems used a resistance wire between the ignition switch and the ignition coil. Its purpose was to drop the voltage down from 12 volts to 6 volts and limit the current drawn by the ignition coil. No resistance and the coil draws too much current causing smoke and parts failure. Depending on how the ignition is wired, it may need a ballast resistor or resistance wire to drop the voltage down.
T
Travis Hufstetler
  • Apr 25, 2012
It's the duraspark setup.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 25, 2012
  • Apr 25, 2012
As you can see, the DuraSpark system uses a ballast resistor. No ballast resistor and things draw too much current and start smoking...
Start looking for the ballast resistor. it will either be a special resistance wire, or a ceramic block with screw terminals or tabs for the wire connections.
Check the voltage at the coil: using the wire that does not go the the DuraSpark box, it should drop from 12 volts in start mode to 6-8 volts in run mode. Use the engine block or battery negative post for a ground. If you get a constant 12 volts cranking or running, the ballast resistor is missing.
See http://webpages.charter.net/1bad6t/duraspark.html for more help.
Or if you are totally bored out of your mind, see http://www.google.com/search?q=dura...-us&ie=UTF-8&oe=UTF-8&startIndex=&startPage=1
T
Travis Hufstetler
  • Apr 27, 2012
Thanks, this will help a lot.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
  • brandyn200
  • Jun 20, 2026
AeroCoupe
