Progress Thread 99 Mustang
99MustangQuinn
Ohio
I have a 99 Mustang with a 04 transmission.. It will only go 29mph before it governs it self out my dash reads 120mph.. I changed the speed sensor but still only will go 29mph.. Would it work if I deleted the speed sensor an I used my GPS as my speedometer? Or is there something else that would work that I can do?
The reason WHY your speedometer is not correct is because Ford changed the number of teeth on the OSS reluctor wheel between the 1999 and 2004 model year. This problem can be fixed by re-programming in the same way as what is required when changing a rear end gear ratio.
The other way to fix this is with a tail shaft swap. Here's some more information that may help.
T-45 Tail Shaft Swap
IMO the best option is to re-program the PCM to correctly understand the different number of OSS speed sensor teeth.
