afr 185cc heads
  • Thread starter Thread starter 32785stang
  • Start date Start date Nov 23, 2006
32785stang
30
  • Nov 23, 2006
I have a set of afr 185cc heads and the springs that come with them are only good to .550 lift. i have a comp cam with .570 lift, does anybody know what springs i should get and where....i dont want to grind the heads either
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 23, 2006
  • Nov 23, 2006
best bet would be to phone arf's tech line and ask them.
1991vert
1,103
Ludlow, MA
Nov 23, 2006
  • Nov 23, 2006
email ed curtis?
32785stang
30
  • Nov 23, 2006
who is that?
1991vert
1,103
Ludlow, MA
Nov 23, 2006
  • Nov 23, 2006
www.flowtechinduction.com he's a custom cam grinder and his other job is being "the man" when it comes to valvetrain stuff
2KsilverGT
354
Collinsville Va
Nov 23, 2006
  • Nov 23, 2006
I bought the AFR upgraded springs. I would contact Ed C cuz I had to have the spring pockets cut to get the AFR's to fit. However I only paid 50 bucks for the springs and retainers and then sold the factory AFR springs on ebay for 40 bucks. 10 bucks in upgraded springs...
R
r.barn5.0
107
  • Nov 23, 2006
Not sure what springs I have on my 185's but they are......
running .579 lift and they have 145lbs seat pressure
125 is stock if i remember right.
89white50
440
central MA
Nov 23, 2006
  • Nov 23, 2006
do you have the cam card for the camshaft? it should give a recommended spring, pressure, installed height, load, all that. or call comp cams directly and ask them, that would be the best thing you could do.
ls1beater4eva
334
mooresville
Nov 23, 2006
  • Nov 23, 2006
ok well we are discussing afr 185 heads i have a set with a set of blue racer rrs does anybody happen to know about what is the common size push rod to use with these heads.
32785stang
30
#10
  • Nov 24, 2006
  • #10
your gunna have to get an adjustable pushrod to check get correct length
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
9
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
Engine Heads and how to buy
  • Dontknowchit
  • Aug 16, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
