Fox allowable axle wear??
The last axle that I removed from a /93 Aerostar had a groove from the wheel bearing oil seal. How deep does the grove have to be before you consider it
necessary to repair? I'm planning to do a 5 lug conversion on my next Mustang. I'm hoping to get all of the parts over the spring and summer. Any advice would be appreciated.
Thanks in advance.
Thanks in advance.
Check with the local auto parts and see if they have a slide on sleeve to fix that problem. The harmonic balancers suffer with the same type of problem and there is a sleeve to fix that.
See Google for a list of suppliers and part numbers...https://www.google.com/search?ei=Ox...ab..1.1.89...0i13k1j0i13i5i30k1.0.wstGKHK6wvw
See how it works...
View: https://www.youtube.com/watch?v=dtvnan20XvQ
SKF SpeediiSleeve catalog with sleeve sizes and information http://www.skf.com/binary/26-128020/11337_2-EN-SKF-Speedi-Sleeve.pdf
See how it works...
The speedi sleeve looks like the perfect solution.
Thanks jrichker
