Every time I drive and my tires go over a bump I can hear what sounds like "sqeaking" high pitch noise from my right rear. Should I just spray that whole area with some WD-40 ..????
I hear a squeaky sound now too, I think it's coming from the seatbelt area tho.
I'm experiencing sqeaky mirriors (both). Iy sould like the plastic components of each mirror are rubbing. I notice it when I close the doors or go over a bump. Any suggestions?
For the OP's original post, it seems to me the sqeak could be rear suspension. I had such a noise in one previous rear sway bar configuration. Sprayed WD40 on one bushing at a time to isolate it, and it turned out to be the right rear end "link" bushing vs. the bar. Next time I made a change I lubricated inside the bushings with silicone grease, the kind Steeda supplied with their front sway bar and billet brackets. Nary a squeak since.wd-40 = water displacement 40 %....find a good silicone...rubber brushings could be dried out
Wouldn't white lithium grease be better than wd-40 or silicone?
