Another Fox TB Conversion thread but different!!!!
69clark
731
Ravena, NY
I am doing a Fox TB conversion on my 1995 Cobra.
2 questions though:
1. Do I lose the use of my cruise control? If not do I use a Fox CC cable or do I use my stock CC cable? Please help clear this up for me.
2. The Fox TB has a vacuum port at the top of the TB. I am not running an EGR system. Do I need this and what is it for on a Fox. And also where does it hook up on a Fox? I would rather leave this off because it will be a cleaner look but I need to know the info on what it is for.
Thanks Guys!
2 questions though:
Thanks Guys!
Cruise works fine with a Fox cable. Your cable will not even bolt up to it...totally different setup. Grab a fox cable and swap it out and you're golden:nice:
With my setup I couldn't get the Fox cc cable on the throttle body. My aeromotive FPR was in the way. Coulnd't bend the fuel rail enough, and didn't think I could hack the cable enought to get it to fit. I'm also running a 3/8" spacer to get the TB cable bracket to fit over the valve cover and heater lines.
That vacuum port on top of the tb was blocked on mine. I wasnt running any egr either. And on my valve cover (oil fill) I have a little breather so nothing get plugged in there anymore.
As for the cruise cable, you have to use a fox 5.0 cruise cable. Very easy to swap and it's a direct fit and works like a charm.
