Anybody install an Edelbrock Vic EFI intake?
1slow95
1,797
ohio
I have the Vic 5.8, but I'm guessing the Vic 5.0 is pretty much the same. It came with a throttle cable bracket that bolts to the lower intake, but I can't use the heater pipes with it. Will it be ok to just use an egr delete spacer and a stock fox throttle cable? Im switching to the fox style TB.
There is a threaded hole in the runner for the #5 cylinder, should I just plug that? I didn't see anything there on the stock intake...
Since there's no PCV, what should I do for crankcase ventilation? I have two breathers I was planning on using, will that work?
Does anybody have a diagram of how the vaccuum hoses connect to this intake since it deletes the factory vaccuum tree? I've had mine apart so long I can't remember where they connect to. :rolleyes:
Thanks guys.
