5spd GT said:I think I have Autolite 24's or 25's not for sure...and was told to gap them to stock gap...(.052-.056) and so I did .054...and I lost 3mph at the track![]()
kevsstang said:Where should i gap auto lite 24's
Mustang5L5 said:3MPH is about 20-30HP. I don't think gapping spark plugs would cause this.
If it is the plugs, you should look at your ignition system. It might not be performing up to spec
5spd GT said:Here is what I did...cleaned the air filter, replaced fuel filter, cleaned IAB and put in new Autolite 24's or 25's???...gapped at .054...and I lost 3mph two days later at the track...
I noticed after that the rpms did not climb as quick in the upper rpms and was confirmed when I went to the track...it acted like the ports on the heads and lower intake got even smaller...know what I mean?...
5.0guy said:I read in a haynes or chilton manual that 85 or 86-89 are .052-.056 and 90-93 are .045...or somethin like that. there was a cutoff year where coil voltage must've dropped or somethin.
