Axle-back, any gain?
NorthwestGT
177
Pasco, WA
I know you might be able to get a different sound, but are there any proven gains from any of the axle-backs? MM&FF ran a test a while back that didn't show anything much better than the OEM mufflers. But, just about every manufacturer claims gains of anywhere from 8-20 HP. Doesn't make sense.
Dear NorthwestGT,
No significant gains but just more sound...
Stock exhaust comes pretty much opened up for the average stang driver...
Dave
The only advantage other than sound is in low end torque & hp. IIRC, at 2200 RPM, the gains were around 40hp & 28 ft-lbs. Which is EXACTLY where the 4.6L motors really need the gains. The numbers start to drop off pretty fast and by the time you're up to 4000 RPM there's no gains at all.
That's all according to the MM&FF test you refered to, but I'm pulling all those numbers from memory.
The stock motor does not respond withmore HP from the reduced backpressure, it actually may lose a few.
I still can't figure out why so may people want to put on offroad H or X pipes. The cost does not justify them in my opinion.
I would love to see a dyno of how a stock motor responds to an X pipe or O/R H.
