I have a 91 coupe that I am starting to do a 5 lug conversion on. I like the maximum motorsportrs 18x8.5 wheels but am trying to decide on which offset to get, they come in 15mm(5 3/8 backspacing) and 36mm (6 1/8) they recomend the 15mm offset for the fox but I am not sure if that is enuff offset to keep from rubbing the fenders. I just got some 95 spindles so I will probably be using them but I haven't bought my axles yet so I could go with sn95 axles or fox lenth depending on witch wheels I go with. It seems like a lot of the wheels that I see on the fox's have more than 15mm offset. What do you think, are the 36mm ones going to rub on the inside of the front or rear? It seems to me that the 15mm ones are not enuff and the 36mm might be too much. I do have Steeda sport springs so the car is lowered a little bit. Thanks for your help
