Balance is most likely for shaking like an expletive (like it will fly apart) at that RPM. The RPM is a specific clue, like a tire that vibrates at highway speed.
Shop mess ups happen, and when they do, it is much worse than a misfire, and is very memorable.
But before tearing it apart,
check the plugs to see if one is different. And check to see if you have spark at each plug. To do that, you can check the wires with an ohm meter and inspect the ignition components. But there are variations on this gadget to see if the spark system is working at each plug. I’d be more comfortable with electronics to try this rather than pulling one wire at a time. If the high output system is not phased by it, a leaky boot will light up your life and the headers are often darn hot.
Lisle Spark Tester Amazon product ASIN B0002STSC6View: https://www.amazon.com/dp/B0002STSC6/ref=cm_sw_r_cp_api_i_VMCHJZPRQJT5N1SBY1PP
