Ya so the GBM got tired of 10 mpg at $5 a gallon up here in nannookville so he bought himself a gem of gas sipper, 89 mercury topaz, 4cyl 5 speed 118,000 kilometers (70,000 miles?) anyways car is decent i went through it and fixed a few things (tie rod end, cv joint boot, o2 senser and front brakes) im all ready to go again on it here but i cant get the brakes to bleed.
It has a master cyl with 4 lines coming off it goin straight to each wheel, no proportioning valve?
i have bled and bled and no air, no fluid, no pedal, no nothing, i could only reach the 2 lines on the master cyl on the side going to the front brakes i pulled them off and no fluid coming out of them, i rigged up some hoses and bench bled them but still no go, I cant reach the bottom lines untill i get my line wrenches from work tommorow. ill try bench bleeding all 4 lines then but in the meantime im stumped, the haynes manuel just explains conventional bleeding methods.
anyone?
-gbm-
anyone?
-gbm-
