  • 1994 - 1995 Specific Tech
Blown HG's again!
  • Thread starter Thread starter 89 blue lx
  • Start date Start date Aug 2, 2004
First Prev 2 of 2
VIPERn94Five-0
3,352
Poughkeepsie, NY
Aug 4, 2004
#21
  • Aug 4, 2004
  • #21
yeah id make sure the heads, and block mate nicely...If they are not totally flat then your just gonna keep blowing them....and what you need to do is do the gaskets, and have the car flatbedded to the shop and get the dyno tune before even driving it....dont just run around with the spout pulled because that is just band-aid fix...get it doen right..
Anthony
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Aug 4, 2004
#22
  • Aug 4, 2004
  • #22
I would try head studs. My reason being that I was told by a ford tech/racer that he prefers head studs because the torque is applied through the entire bolt were as the head bolts applys the pressure through the head of the bolt only . Made sense to me as he explained his reasoning for it.
Killercanary
The car that set the bar.
Altoona, PA
Aug 4, 2004
#23
  • Aug 4, 2004
  • #23
Studs are definitely the way to go, especially if the heads are removed a lot (cough cough!). The reason in addition to what WYTSTANG said, is that you will have less of a chance to strip the bolt out of the block since the stud is installed and then the nut is torqued on the stud itself and not the threads in the block if that makes sense.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 4, 2004
#24
  • Aug 4, 2004
  • #24
I assume you have a boost gauge, right? I think I remember seeing it before.
Are you still seeing 12psi?
If you were only at 7-8psi, this would shock me. But with the extra boost & no tune, you heated the HG's beyond their limits (i.e. detonation).
You are lucky you didn't blow a piston or a head component.
Scott
yellow5.0cobra
2,849
In the garage, On the floor.
Aug 4, 2004
#25
  • Aug 4, 2004
  • #25
i said the uneven head surface oh about... 15 posts up.
those ARP's are probably torqued out...
I would definantly put in studs and use some COMETIC gaskets.
D
DARK-5.0
724
Leawood, KS
Aug 17, 2004
#26
  • Aug 17, 2004
  • #26
DP
D
DARK-5.0
724
Leawood, KS
Aug 17, 2004
#27
  • Aug 17, 2004
  • #27
Not to jack the thread but it seems that there are a lot of head gasket gurus in here. I am needing new head gaskets for my AFRs. I had some ROL on mine but for some reason I had a strange coolant leak and the heads were torqued to spec. What torque rating do you guys set your heads at. The gaskets are for the combo in my sig. Thanks
Jeremy
94TURBO5 O
2,509
VA
Aug 17, 2004
#28
  • Aug 17, 2004
  • #28
I torqued 85 lbs before and now on this pair I went to 95 lbs.
You need to make sure the surfaces are clean and perfect on the block and heads. Make sure the heads are level as well. I have been lucky that the last 3 changes the heads & block were straight still. I think thhe key to that is shutting off immediately.
D
DARK-5.0
724
Leawood, KS
Aug 17, 2004
#29
  • Aug 17, 2004
  • #29
So are the ratings in a haynes manuel underated you think for torquing the heads down. What damage can be caused with an overtorqued headgasket, aslong as all the bolts were torqued exactly the same.
Jeremy
94TURBO5 O
2,509
VA
Aug 17, 2004
#30
  • Aug 17, 2004
  • #30
To be honest I don't know what bad could happen but it's worth a try once. I have popped HG's from detonation 3 times in the last 3 months. I think that they are not underrated but I'm sure OEM specs didn't anticipate me adding 12 psi to the block either so I made my own rating for my car.
D
DARK-5.0
724
Leawood, KS
Aug 17, 2004
#31
  • Aug 17, 2004
  • #31
True, boost is not so friendly to stock specs. So what gaskets do you recommend for a h.c.i car like mine.
Jeremy
94TURBO5 O
2,509
VA
Aug 17, 2004
#32
  • Aug 17, 2004
  • #32
ROL and Cometic seem to be the best out there for boosted cars. I am running OEM spec HG's.
Killercanary
Altoona, PA
Aug 17, 2004
#33
  • Aug 17, 2004
  • #33
Jeremy, if I'm not mistaken AFR recommends different torque specs for the top and bottom head bolts. I could be wrong but check with them to make sure. Also, check with the HG manufacture and see what they say, if you over torque it that may be bad too as it could over compress the gasket and deform it. I don't know if it will do this, but I can see how it would.
94TURBO5 O
2,509
VA
Aug 17, 2004
#34
  • Aug 17, 2004
  • #34
True, good point sort of like the old cork valve gasket squeeze mess.
Yeah kinda do as I say and not as I do. I always go against the grain with my car and try all kinds of exp'mntl stuff on it. I left off one of the ps bracket bolts (one under the pulley) so the next time I have to do a HG install I won't have to pull the ps pulley off again (major PITA). I have had no adverse effects from it , but just an idea.
Y
yellow1995Cobra
2,959
Massachusetts
Aug 17, 2004
#35
  • Aug 17, 2004
  • #35
Get the injectors flow tested before you run it again. How many cyl's are blowing out each time?
I know the feeling man
First Prev 2 of 2
M
Location of Seat Restraint Module - 2001 Cobra
  • mzbhavn
  • Aug 28, 2025
  • SVT Tech Forum
SVT Tech Forum Aug 30, 2025
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
M
93 5.0 Microsquirt with Stage 3 trickflow tuning issues
  • marxpreston11
  • Jun 22, 2026
  • Digital Self-tuning Forum
  • 2 3 4
2K
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
